![]() | Home > General > 3.0 TDV6 'SE' vs 3.0 TDV6 'HSE' MY2010 onwards |
Charlieb Member Since: 23 Jul 2015 Location: london Posts: 4 ![]() ![]() |
Hi all,
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2019 ![]() ![]() |
Sdv6 with 8 speed is very refined and >30mpg |
Marvik125 Member Since: 02 Jul 2015 Location: West Midlands Posts: 139 ![]() ![]() ![]() |
I have a TDv6 6speed and was given a 2015 Disco 4 8 speed as a courtesy car. There really is not much in it, providing your gearbox is running correctly.
If just done Shrewsbury to Barmouth and back and fuel comp is saying 35.4MPG. I did intentionally drive to see if I could get a half decent MPG though. |
Mpg not really a consideration if its over 25ish. I currently get around 26.5 from my family car so sounds like it will be an improvement in any case. I would absolutely be looking for a v8 or supercharged if they hd even remotely reasonable consumption.
HSE/SE etc are interior/exterior specs only. They do not refer to the engine or emissions. |
OK I see!
In 2010 the only TDv6 for the RRS was the 3ltr, later on at the end of 2011 I believe the SDv6 was introduced with more power and the 8 speed automatic gear box. |
ilard Member Since: 20 Aug 2010 Location: London Posts: 975 ![]() ![]() |
Standard features for all 2010MY: |
Willywilson1980 Member Since: 05 Oct 2015 Location: Chester Posts: 9 ![]() ![]() |
I'm new RRS owner so no expert. I asked myself similar questions between SE and HSE trim and also engine differences in the TDV6 (2010) and SDV6 (late 2011 onward). As per previous post SE / HSE makes no difference to engine. The latter spec has memory seats and nicer leather / wheels I think. I found the SE trim was cheaper and more rare so wanted HSE as I hope will hold value better (no idea though). The 8 speed was introduced with the SDV6 I think and included an engine remap making it more efficient. When I discussed with LR I also learned the newer 8 speed model has different firmware (infotainment), HDD, dual view screen, paddle shift, and electric tailgate as well. So not all that much changed with the 12MY vs the 10MY but for me it was worth the extra cash to get the SDV6 (8 speed). I drove both engines and think there's little difference in the drive. There did seem to be quite few changes to the overall spec though. |
