![]() | Home > General > TDV8 Turbo failure |
Erniedog Member Since: 20 Jul 2015 Location: England Posts: 3 ![]() ![]() ![]() |
Hi All. After some advice. I have a 2010 V8 90,000 miles with a EGR system fault coming up on the computer even straight after it is cleared..The vehicle goes into restricted performance mode as soon as it is turned on. There is i assume engine oil that has dripped over the floor and has oil in the intake system inter cooler & pipes. Will the faulty EGR valve cause this oil to ingress into the pipes or is there other problems possibly underlying. I have someone looking at it soon, but just want to prepare for any bad news that they may give.....Thanks in advance for any advice |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4512 ![]() ![]() ![]() |
There is no oil in the EGR system... |
You can tell I have no mechanical knowledge whatsoever. What can be a possible cause for the oil
Most probable cause will be a turbo issue. Is there lots of oil, or is it just a misting of oil? |
Quite a bit. Definitely not a misting |
