![]() | Home > General (L494) > Locking your keys inside a RRS with comfort access |
| PauloAmore Member Since: 27 Jan 2007 Location: Bonnie Scotland Posts: 1293
Yup - doable....
| philmw Member Since: 18 Aug 2006 Location: Nottingham Posts: 1690
There are (I think) 7 key sensors around the car including in the boot to stop this from happening, but do know of it happening to an Evoque so is possible. Probably a combination of location and other stuff forming a black spot.
The not closing and beeping when the key is inside is what normally happens. If, however, the key is in a dead-spot or blocked by other things around it then the boot will shut with the key inside. For the Evoque case I menioned, the car was locked and then the boot opened, the key was in a bag that was put in the now open boot and then the boot closed, and locked. |
Change the wife? |
| robbo770 Member Since: 13 Nov 2013 Location: Aberdeen Posts: 248
Gone rejected RRS autobi Dynamic MY14.5 (Peter Vardy 👎) D3 XXV full conversion 4.2 SC FFRR 4.4 FFRR Freelander 1 |
| forest172 Member Since: 03 Apr 2013 Location: Derbyshire Posts: 104
Happened to us yesterday. Wife opened boot with comfort access and with key in her handbag. She put handbag in the boot with key inside and shut the boot.
| Mr Rusty Member Since: 17 Jan 2016 Location: Aberdeen Posts: 376
Whenever our car detects a key inside it won't allow you to lock the car. However it does appear to have a black spot near the back of the boot as the car won't start if the key in my wife's bag at the back. Different car I know, but just my experience.
| Dave777 Member Since: 15 Feb 2015 Location: Sussex Posts: 485
Comfort access is the BMW keyless system like this. It will not let you put your key in the boot and close it. I know I have tried.
If you place the key in the boot and try to shut the boot with the car locked, it does a double beep and re-opens the boot.
