![]() | Home > General > Colliers Land Rover Birmingham |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2796 ![]() ![]() |
I have visited there a few times - always busy & polite when I have been spoken too but ( time & distance allowing ) I would drive it back to them & kick it off |
Not necessarily; I wouldn't be worried about it unless I found a time stamped fault code that they should therefore have seen. These cars do throw up faults without warning. With a two year warranty, they'd have nothing to gain by it anyway. ![]() 2006 Discovery 3 TDV6 Auto HSE Zambezi Silver ![]() |
Marvik125 Member Since: 02 Jul 2015 Location: West Midlands Posts: 139 ![]() ![]() ![]() |
I will see what LR Assistance say, I really do like the car though. I will give them a fair chance before screaming at them. I did some research before buying a used RRS so I knew the chances are it WILL go wrong at some point. Hence I went to a main dealer with the 2 year unlimited mileage warranty an 2 year LR Assistance. If this was a side of the road forecourt I would be in a mild panic about now. But I'm not worried "yet" |
I agree with what you say & as already mentioned if the fault as no historic codes then it`s pure bad luck |
The most likely causes of such a fault would be a bad suspension calibration, faulty height sensor (or wiring) or perhaps a restricted air pipe/blocked air drier or similar. |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2021 ![]() ![]() |
I'd just ask them nicely to check it over. I too have just bought a 2012 model and have had them do a couple of niggles - all for nothing. Not from your dealer though. Just be polite but firm |
The Bad- Its having a new compressor fitted Monday. Also exhaust mentioned, but not the engine exhaust.
Result. Its what you pay a bit more for via a main dealer. Use the services offered to the full |
Excellent. If the compressor doesn't exhaust correctly it can certainly have that effect. |
Good result |
Wasn't sure when they started fitting them... ![]() Are they a lot more robust and reliable than the Hitachi? * Current. 2024 D350 Defender 90. Too many modern gimmicks on it ! * GONE. 2012 RR Sport HSE SDV6 Orkney Grey. Now being piloted by RRSTDV8 * GONE: 2011 4.4 TDV8 Full Fat. Amazing piece of kit. * Current. 1974 Lightweight 2.25L petrol. Old skool I use www.glenrands.co.uk Great independent * 1949 80" in family since 1975 |
Brother uses Shukers - good service, been around for yonks.....
They've certainly proved to be a vast improvement over the Hitachi. ![]() I believe they switched to them during 09MY. ![]() 2006 Discovery 3 TDV6 Auto HSE Zambezi Silver ![]() |
