![]() | Home > Technical > Metal weights under rear bumper ? why ? |
| ABSport Member Since: 14 Aug 2014 Location: Plymouth Posts: 698
Stop Travel sickness |
| roscopcoltrane Member Since: 31 May 2013 Location: Scotland Posts: 86
Harmonic Mass Dampers |
| TDV8_AutoB Member Since: 03 Jul 2015 Location: Berkshire Posts: 35
Nice - what genius decided that they would be a good idea ? I wonder how much they weigh ? Clearly got to have some effect on economy.
| BKHK Member Since: 05 May 2008 Location: Perth Posts: 1942
Don't take them off. |
| DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2025
Yes. Leave alone. LR put them there for a reason |
Thanks for the advise guys - much appreciated, will leave them alone. |
| npinks Site Moderator Member Since: 26 Nov 2007 Location: Watching Posts: 6716
are you sure a RRSport is the right car for you if your worrying about economy |
Nah - not worrying about economy at all. It's better than the RS6 for sure. Just wondered what the heck they're for - now I know - but certainly they will effect economy, just like driving an aerodynamic brick also does.
| Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477
Any weight will affect economy, but when you consider the weight of the chassis and the rest of the vehicle, it pales into insignificance! Visiting from DISCO3.CO.UK
| Mr Messy Member Since: 14 Jun 2015 Location: Reading Posts: 22
I used to be a helicopter technician and we used something similar in the nose to reduce harmonics, pimimtive but effective.
Brilliant - you should work for JLR ! That'll save them a fortune |
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5154
That's Assuming Nobody's already nicked it of course. Cheers Col |
Mr Messy
| idrabble Member Since: 25 Oct 2013 Location: Brisbane Posts: 61
I worked on Westland Lynx for 15 years and the vibration absorber on top of the Main Rotor Head had to be tuned using a series of extra circular rings you bolted under the top cover. Used to love doing that job, we called it 'Bonk Testing' as you attached a piece of electrical kit to the vibration absorber to take the measurements and then 'bonked' it on the side with your hand. |
| All times are GMT |
