Home > Maintenance & Modifications > EGR blanking
Page 3 of 4 <1234>
Nsp1
United Kingdom 2006 Range Rover Sport TDV6 HSE Bonatti Grey
Oh no!!! Rolling Eyes
Now you tell me.
Where are they?
Post #451739 Sat Feb 07 2015 8:54pm
Nsp1
Can anyone help me on this please?
Post #452242 Wed Feb 11 2015 4:49pm
Lost for Words
The main one is the big hose coming out from the front right side of the engine which comes up from the intercooler. You can access the other end of this through a panel in the wheel arch which is held in by plastic rivet things. This is the most common one to fail but the others have been known to go too.
The other two on the nearside are harder to get to. You have to remove the wheel arch liner to get at them, though the top of the larger of the two can just be seen and felt from the engine bay.
http://www.disco3.co.uk/forum/topic94971.html Thumbs Up Visiting from DISCO3.CO.UK
Post #452245 Wed Feb 11 2015 5:11pm
Nsp1
Thanks, I'll have a look tomorrow.
Don't want them splitting.
Post #452385 Thu Feb 12 2015 9:29pm
Nsp1
There are no splits I any hoses as yet but I'll keep my eye on them.
But there is still black smoke when I stick my foot down. I thought the blanking kit stops this.
Post #453135 Fri Feb 20 2015 3:21pm
Lost for Words
I'm assuming the car is not remapped, as this can cause some smoke?
Have you checked the intercooler itself for leaks? You might see oil leaking out if so. Thumbs Up Visiting from DISCO3.CO.UK
Post #453145 Fri Feb 20 2015 4:30pm
Nsp1
No, the car's not remapped.
And you know the next question... ...where's the inter cooler? Ha! Sorry. I'm a novice.
Post #453147 Fri Feb 20 2015 4:45pm
Lost for Words
Sorry. It's down low behind the bumper, beneath the radiator. The two larger hoses connect into it (at the back). Thumbs Up
They aren't very good (being small and thick) and block up easily (I've fitted an uprated one Mr. Green ). Rolling Eyes Visiting from DISCO3.CO.UK
Post #453150 Fri Feb 20 2015 4:55pm
SeQ
Lithuania 2007 Range Rover Sport TDV8 HSE Java Black
just want to proceed with same theme..
i think my TDV8 3,6l RRS started to give EGR error P140A (left side egr).
there is a possibility to change this EGR, but to blank both EGRs would cost less and i think it would be even better.
so has anyone blanked EGRs in these yellow marked places:
maybe TDV8 EGRs should be blanked in other place?
i think to leave both egrs in their places as it is require a lot of working hours just to remove them and blank all tubes for air, cooling and etc.
Thanks.
Post #465772 Fri Jun 26 2015 8:31am
Lost for Words
I'm not sure there is a readily available solution for 3.6 TDV8 blanking (yet). I imagine it would have to involve a software patch as is the case with the EU4 TDV6.
Let us know if you find a solution. Thumbs Up Visiting from DISCO3.CO.UK
Post #465791 Fri Jun 26 2015 10:22am
SeQ
well i just noticed that when engine cold (after night) and i start engine after 2-4 seconds exhaust gives a lot of smoke and engine hardly accepts throttle. but after 2-3 sec everything becomes normal.
i think it could be that EGR does not work properly.
Vehicle do not give any error at the moment. but i dont see it normal as it was not few days ago.
in the other hand, if no one yet blanked EGRs on TDV8 3.6 then i dont want to be rabbit Wink
i would rather try to clean or change this egr to new one..
Post #465796 Fri Jun 26 2015 11:26am
Lost for Words
Blanking, if possible, would always be the best option, so it would be nice. I would imagine it is being worked on by someone. Visiting from DISCO3.CO.UK
Post #465799 Fri Jun 26 2015 11:30am
SeQ
so no one heard that someone has already blanked 3.6l ? Smile
i guess if someone would i could buy blanking kit in ebay or else where..
Post #465800 Fri Jun 26 2015 11:33am
Lost for Words
Alive Tuning wrote:
Very simple to do on the 2.7, and slightly more complicated for the 3.6 TDV8 where the throttle bodys have to be disconnected to keep them in the open position.
Just found this which implies it has been done. Might be worth speaking to Gary @ Alive Tuning about it. Thumbs Up Visiting from DISCO3.CO.UK
Post #465803 Fri Jun 26 2015 11:44am
Disco_Mikey
Gary @ Alive Thumbs Up
Post #465805 Fri Jun 26 2015 11:56am
Page 3 of 4 <1234>
