Home > For Sale & Wanted > [For Sale] [NOW SOLD]2005-2009 Paddle Shift Convertion Parts
These parts allow you to fit Paddle Shift Switches to your 05-09 Sport, you will however need a 2010 on Steering Wheel.
They also allow the option to control the ACC and Heated Steering Wheel from the Switch Packs, but obviously the car needs to have ACC fitted and you will need the Heated Steering Wheel and latest Clock Spring. It is also possible to control the Audio from either the L/H or R/H switches as the earlier cars do not have the menu option on the steering wheel the same as the MY10 on cars.
I have included the small wiring harness and later clock spring needed but one or the other has a slight fault. They were removed from my 12plate car which kept showing a fault so I changed both which cured the fault, rather than remove the airbag several times so I don't know which is the suspect part.
If you do a search there are a few post regarding this conversion, there is also a quite comprehensive post on the Disco forum as well, as I believe this can be this can be fitted to the Disco 3 as well. Check out Blackbox Solutions website for all the info. as well as it was Colin there who designed and supplied the Circuit Boards. The Original Switches etc. came new from Dan at Duckworths.
Removed these bits from my 09 plate before I sold it.
Looking for £150.00 inc. delivery.
Post #465279 Sun Jun 21 2015 12:59pm
Disco_Mikey
This is 48 hours too late. Just ordered them direct from BBS Big Cry
Post #465285 Sun Jun 21 2015 2:52pm
brjp1
United States 2008 Range Rover Sport Supercharged Zermatt Silver
PM Sent!!
Post #465627 Wed Jun 24 2015 9:41pm
