Home > Technical > relocate the aux and cigaret lighter
jorn
Belgium 2009 Range Rover Sport TDV6 HSE Stornoway Grey
i found it very annoying that the aux and 12v soccer is at the back of the rear console.
with 3 kids at the back its not very handy.
i'm thinking of replacing them to the inside of the cubbybox. if i could just pull the panel out, dril a hole in the inside and replace the panel in a cutout there.
somebody did that? or will i have to remove the hole console?
thx for any advice
Post #465536 Wed Jun 24 2015 10:09am
Bodsy
Site Sponsor
You could relatively easily. (Assuming you dont have the fridge in there)
So intructions on how to get the cubby out, you could try following the Fridge fitting instructions here:-
http://www.rrsport.co.uk/gallery/albums/us...330PVJ.pdf
Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #465541 Wed Jun 24 2015 10:18am
jorn
thx for the tip.
the panel with the aux can you just pull it out you think? or are there any hidden screws.
i would trie to cut the box without to remove it, cause i always worried about a cracking landrover, as this one is my first one without any Wink
Post #465543 Wed Jun 24 2015 10:23am
Bodsy
Site Sponsor
On the D3 it can just pop out, so I assume same for RRS, it's been a while since I last fitted the RSE on a RRS.
There may well be enough space to get a dremmel in, but should be easy enough for you to check. Thumbs Up Bodsys Brake Bible
See it HERE
Post #465545 Wed Jun 24 2015 10:27am
jorn
thx, will check this afternoon, was also thinking of cutting with a dremmel.
will keep you posted if it all worked well, maybe i trie to find a replacement for the back so i have double aux and 12v for the kids
Post #465546 Wed Jun 24 2015 10:32am
