Home > Technical > RRS 3.6 TDV8 2007 Lower intercooler
SeQ
Lithuania 2007 Range Rover Sport TDV8 HSE Java Black
Hi all,
it seems that lower (not upper blue one) intercooler tube is making sound.
https://www.dropbox.com/s/1phsod3xzacdf9f/...5.mp4?dl=0
any idea how to change it? can i do it myself or i should go to service.
the problem is that car started to give lots of black smoke and it seems it lost 50 kw..
i hope it is only tube...
Post #464429 Sat Jun 13 2015 6:45am
SeQ
Problem solved
if i am correct this tube was broken:
8A595- LR008237
yellow:
Post #464645 Mon Jun 15 2015 2:57pm
8A595 is a coolant hose, not part of the induction system, as far as that diagram is concerned. The yellow-marked pipe is the cylinder head coolant pipe.
The induction system is shown here (note that there are two turbos but only one shown in the diagram):
http://www.rrsport.co.uk/gallery/albums/us...0pipes.pdf 2012 SDV6 - it's missing a couple of cylinders
Post #464656 Mon Jun 15 2015 4:38pm
SeQ
well but it was the issue for black smoke, low power.
i changed it to another one and vehicle works just perfectly.
Post #464669 Mon Jun 15 2015 6:02pm
Presumably you moved something else whilst doing the work and that sorted the problem - a loose connection somewhere for example. 2012 SDV6 - it's missing a couple of cylinders
Post #464748 Tue Jun 16 2015 7:13am
Disco_Mikey
The pipe in the yellow box IS part of the boost system Thumbs Up
Post #464779 Tue Jun 16 2015 12:42pm
Looking at it again, is that the variable interconnect pipe? If so mea culpa and I stand corrected Embarassed 2012 SDV6 - it's missing a couple of cylinders
Post #464780 Tue Jun 16 2015 12:51pm
