Home > Maintenance & Modifications > Wheel alignment - now issues.
mr_spaceuk
Hi all. I've had a Hunter wheel alignment at Kwik Fit about 4 week ago, my RRS hasn't handled the same since, I thought it was just me but my wife has mentioned it as well and that's saying something!
They said they had to put it in maintenance mode for the suspension to do the alignment.
I've not a clue what the values mean on the readout they gave me but all 4 corners where in the red and now in the green (I'm sure that makes sense to someone hahahaha!).
My issues are that the steering wheel is no longer pointing central on straights but off to the right (offside) but the car is pulling to the nearside.
Both front tyres are now badly worn on the outer edge, to the point that I might be looking to replace them in the next couple of weeks or I'm going to start to see threading.
I never had these issues before I took it in and tyre ware was very even!
WHAT HAVE THEY DONE! Big Cry
Post #463289 Sat May 30 2015 4:19pm
Russben
Post up the image of the readouts on here & one of the site sponsors will tell you if it's right.
I wonder if they thought 'maintenance mode' was in fact access height? That'd screw up your geometry. I'm in the shed, I'll be back in the real world in a minute.
Gone- 2010 TDV6; Hello 2017 SDV6.
Post #463405 Sun May 31 2015 9:54pm
myfirstrrs
I had just the same, had a Hunter's alignment at a place I used last year with great success (not Kwik Fit) and since then all sorts of problems with steering wheel not being straight and tracking wrong. I took it back twice and they realigned the steering wheel, just to go wrong again within an hour or so. After all this happened the LR Dealer changed my sump gasket that I believe is a big strip-down job and my local garage said that tracking was way out. It's now going back to Dealer to check the alignment but I am fed up of all the messing around.
Post #463413 Mon Jun 01 2015 6:22am
Paddi
Re: Wheel alignment - now issues.
At the risk of stating the Censored obvious.... they haven't followed the correct adjustment procedure.
You can help a little by making sure the fuel tank is full and the tyre pressures are correct before taking the car in but after that it is up to them.
The suspension should be put in 'Tight Tolerance Mode' before starting the job.
Take it somewhere else that knows how to do it properly; get a report on the initial condition of the adjustments and take that back to Kwik Fit to justify a full refund. 2008 MY Java Black TDV8 HSE
Post #463579 Tue Jun 02 2015 3:10pm
gogsy1956
I think i would be very reluctant in going to the likes of quick fit to get this type of work done, as Paddi says, have they done it correctly. Just beacause they have a Hunter machine is no guarantee they can use it correctly orhave even used the correct data to setup your suspension.
The Indie i go to use a Beissbarth ML8 machine and a specially calibrated wheel alignment ramp to carry this work, i had mine done during the replacement of the front lower arms last year and have had no trouble at all.
I did also enquire about this "full fuel tank " requirement as a few people had mentioned it on here but they said there was no need for this as they would lock the suspension at the correct height before any work was done 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #463587 Tue Jun 02 2015 4:53pm
mr_spaceuk
At the time the tyre pressures where correct and I normally run with a fuel tank at 3/4 full or above.
I think im going to give kwik fit a wide berth from now on.
How is 'Tight Tolerance Mode' activated ?
Post #464244 Wed Jun 10 2015 3:33pm
Paddi
Tight Tolerance mode is activated via the OBD port using an appropriate diagnostic computer such as the IID tool. Any serious workshop will be able to do it. Workshops that don't have the kit will try to convince you it is not necessary but they are wrong.
Re the full fuel tank thing - it is in the official workshop manual (in red text) so I always observe that. 2008 MY Java Black TDV8 HSE
Post #464246 Wed Jun 10 2015 3:53pm
mr_spaceuk
I very much doubt any "drive in" garage around here would have a IID Tool to set this all up correctly. Might have to give the RR Dealer a call and see if they offer the service Crying or Very sad
Post #464260 Wed Jun 10 2015 5:21pm
Paddi
aaaaaaaagh! No please.......the last thing I intended to do was drive you into the arms of a franchised dealer where most likely the spotty apprentice will screw up your alignment and then you will be charged an extortionate labour rate and advised you have all sorts of other 'faults that need atention'
Look on the Hunter 'align my car' website and there will be a competent place near you somewhere. Laughing 2008 MY Java Black TDV8 HSE
Post #464271 Wed Jun 10 2015 6:56pm
Gaz
England 2007 Range Rover Sport TDV6 HSE Stornoway Grey
I'm having 4 new tyres fitted tomorrow and have decided to have the geometry checked to help prevent any uneven wear.
Having mine done at Brunel Tyres in Bristol.
They do the checks for Guy Salmon Bristol so peace of mind.
My garage said that are a lot of places out there with the equipment but not the knowledge to correct any faults properly!
Gaz. I was born with a photographic memory. Shame it didn't develop!
".....do you boys know what the word Nemesis means?...."
2007 2.7 TDV6 in Stornaway Grey.
EGR Blanked.
Re-mapped by Alive Tuning.
Post #464304 Thu Jun 11 2015 1:25pm
Paddi
Perhaps you could post your impressions and the print outs of before and after alignment?
According to their website the Snap-on alignment system is used, not the Hunter System. 2008 MY Java Black TDV8 HSE
Post #464312 Thu Jun 11 2015 2:18pm
harrygh60
England 2010 Range Rover Sport 3.0 TDV6 HSE Fuji White
[quote="Paddi"]aaaaaaaagh! No please.......the last thing I intended to do was drive you into the arms of a franchised dealer where most likely the spotty apprentice will screw up your alignment and then you will be charged an extortionate labour rate and advised you have all sorts of other 'faults that need atention'
Look on the Hunter 'align my car' website and there will be a competent place near you somewhere. :lol:[/quote] I would not recomend Kwic Fit Either.My friend who is mechanicaly minded was told he had to have a whole exaust system,as it came in one piece My friend showed them the joins in the exaust system. They then fitted the rear box,that was all it needed.
I had Hunter allinement carried out, and it was purfect Steering wheel straight ahead ,and felt easy on the steering. That was 7 Months ago and no Tyre wear itisme
Post #464317 Thu Jun 11 2015 2:54pm
Gaz
Brunel Tyres are independent and are a business in their own right.
What I'm saying is that because they know what they're doing, Guy Salmon Bristol send vehicles there when an alignment needs checking.
I've already spoken to the manager and he can do a geometry check/4 wheel alignment plus adjustments for £70.
I'm not well enough informed to know if the Snap On system is better than the Hunter system. Thumbs Up
EGR Blanked.
Post #464328 Thu Jun 11 2015 4:44pm
flack
Its not the equipment thats at fault its the monkeys that are using it, I can't understand why they get it wrong because they are shown on the screen what to adjust and how much to adjust it... even if you did not put it in TT mode or even a full tank of fuel, there is no excuse to get it wrong with the Hunter kit...
Flack Thumbs Up
Post #464349 Thu Jun 11 2015 8:25pm
mr_spaceuk
GOOD NEWS!
I have found a local garage that has laser alignment gear and actually knows what they are on about, only a small independent company and the owner also has a RR, although its a full fat. We had a good chat and its going in next week to be looked at and sort some other stuff out too.
Also to for info's sake, kwik fit didn't have the car in Tolerance Mode but had it in Access Height. Censored
Post #464357 Thu Jun 11 2015 9:38pm
