![]() | Home > Maintenance & Modifications > Hill Descent Control |
Don't have in-depth knowledge but it uses ABS: https://live.landrover.co.uk/technology/la...technology
Very similar to cruise control really. It's controlled by the Vehicle Dynamic Module (AKA ABS module |
Member RRSTDV8 posted this useful document (which covers terrain response controls) a while back ... if you are interested. Current: Volvo XC90 T8 Inscription Pro PHEV with some optionals on top
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9090 ![]() ![]() ![]() |
HDC uses the brakes to control the vehicle's speed. It controls individual wheels and makes use of the ABS wheel speed sensors to monitor what is going on at each corner. It's part of a suite of systems that make up the Terrain Response system.
Black Bess Member Since: 09 Sep 2013 Location: Lincolnshire Posts: 245 ![]() ![]() ![]() |
Thank you all for such brilliant information. I am going to read the Graz paper on the way home (on the train, not whilst driving !!).
Do you mean "Why can't a single wheel be turned when only it is off the ground?" by that? |
Doh !! I wasn`t thinking about it being in park. Will try that out when I next have the car on the jack. |
Do you have the gearbox in park when you jack up one corner? That will prevent the wheel rotating. Have it in neutral (with the grounded diagonally-opposite wheel chocked to prevent rolling if necessary) and you should be able to rotate an individual wheel when its lifted.
