![]() | Home > Maintenance & Modifications > Air Conditioning Condener - price to replace? |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4506 ![]() ![]() ![]() |
Fairly involved job, but not particularly difficult. From memory, its about 3-4 hours
simonj007 Member Since: 11 Sep 2013 Location: Buckinghamshire Posts: 148 ![]() ![]() ![]() |
A local dealer has just quoted...
They're charging for air now!? |
Fish Member Since: 29 Jan 2014 Location: Glasgow Posts: 60 ![]() ![]() ![]() |
Is that for the air they are breathing while they do the job? ![]() |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2796 ![]() ![]() |
duckworthparts Site Sponsor Member Since: 13 Mar 2009 Location: Market Rasen Posts: 674 ![]() ![]() |
Part JRB500140
JasM Member Since: 02 Nov 2012 Location: Lanarkshire Posts: 1186 ![]() ![]() ![]() |
£1332! |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 954 ![]() ![]() ![]() |
i think the 7p charge must be for refrigerant ( gas ) to recharge the system, AC systems are rated by weight of refrigerant 2010 RRS, TDV8
The first post asks about condenser change and the quote is for a compressor change. Which is it? 2008 MY Java Black TDV8 HSE
My local independent garage have just quoted:
I think a stone would be the least likely to cause damage, the condenser is basically built the same as a radiator, it will suffer from age, corrosion and also vibration issues which can cause fractures in the welded seams / joints. These are normally not visible to the naked eye unless its had some obvious physical damage, only way to test them is to pressure test, normally with nitrogen and use a soapy solution to check all joints. 2010 RRS, TDV8
simbad111 Member Since: 10 Feb 2014 Location: wolverhampton Posts: 114 ![]() ![]() ![]() |
did my own, got the condensor for £180 not the hardest job but still few hours work involved, see my gallery |
Hi, Is that price correct as TotalParts list it as follows: JRB500140 : CONDENSER £196.38 |
