![]() | Home > Maintenance & Modifications > Servicing air compressor |
RonyTed Member Since: 03 Feb 2013 Location: Cannock Posts: 17 ![]() ![]() ![]() |
Hi Morgi, removed and replaced my compressor with a new one this week did not disconnect the battery and no probs at all, but would suggest you let the car go to sleep first. I think people are saying disconnect battery to clear faults? dont know if this works as i used IID to clear all faults. |
daxmatt Member Since: 16 Aug 2014 Location: kent Posts: 206 ![]() |
keep us posted how it goes,,need to do mine soon |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 953 ![]() ![]() ![]() |
Hi Morgi, had mine off once to replace the alloy mount ( trolley jack in wrong place ! ), did not disconnect the battery, couple of warnings when i first switched on but soon cleared.
Morgi27 Member Since: 31 Jan 2015 Location: Birmingham Posts: 88 ![]() ![]() ![]() |
Cheers guys has I say the compressor is fine and no warnings Etc, just I want to replace the lid from the plastic one to the metal one so I don't get that split inbetween the pipe outlets
