Home > Technical > Stealers locked my brakes - advice needed |
Mavman Member Since: 07 Jan 2007 Location: London / Wiltshire / Verbier Posts: 7 |
I recently took my RRS SC 06 to the Salisbury dealers prior to a family trip abroad; just to check a couple of warning lights that can usually be cleared on the whizzy LR diagnostics laptop as had bee done before. My cruise control was being intermittent - something I wanted driving down through France.
Tue Jun 02 2015 1:56pm |
Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477 |
Tue Jun 02 2015 2:15pm |
You press the brake pedal when installing it or release it before fitting. Visiting from DISCO3.CO.UK
Tue Jun 02 2015 2:49pm |
Actually, the chap who did the replacement was their most experienced LR technician, and was introduced as such with some reverence as to his skills. To be fair to him, once I had limped to the Pewsey garage he immediately helped them worked out the problem as they were trying to fault trace - unless the switch isn't properly seated until it made a loud 'click' which he had them do over the phone.
Tue Jun 02 2015 5:07pm |
If you ever want your "tea leaves" read, I'd happily oblige for nothing. I expect £95 is their hourly labour rate. John Ottons is the man in charge of the workshop and former owner of the dealership. Visiting from DISCO3.CO.UK 2006 Discovery 3 TDV6 Auto HSE Zambezi Silver |
Wed Jun 03 2015 10:13am |
Ian.H Member Since: 04 Oct 2014 Location: England Posts: 180 |
I know not entirely related, but... I took my old BMW E30 into a garage to have the same done as someone told me my brake lights kept flickering on and off which on the motorway. The car came out with the same fault.. but new brake pads! Apparently the person on reception thought I'd booked it in for "brake paddles" instead of the requested "brake pedal switch". Needless to say I didn't bother going back to have the switch fitted (ended up doing it myself as I had more time at that point) and had a bit of a "word" with the garage owner. It's amazing what people can / do do. Cheers.. Ian |
Thu Jun 04 2015 12:36pm |
RogerDeFlor Member Since: 28 Mar 2015 Location: Gloucester Posts: 51 |
I still don't understand how a partially fitted switch can apply the brakes ???
Wed Jun 10 2015 4:07pm |
Well it is the brake switch... Visiting from DISCO3.CO.UK
Wed Jun 10 2015 4:19pm |
yes, but I just assumed that the pedal actually applied the braking force (with the help of the servo), the switch just told the ECU that the brakes were being applied, and hence the brake lights. Or is it brake-by-wire now ? |
Wed Jun 10 2015 4:26pm |
The pedal does apply the brakes, but there's still a feed from the brake switch to the ABS module which can control the brakes as it sees fit (It's one of the most impressively advanced systems around, IMO, when you consider what it does. ). Visiting from DISCO3.CO.UK
Wed Jun 10 2015 4:30pm |
