Home > Technical > CD player steering wheel controls sometimes swapping around
RRSSte
I have a 2005 RRS and the steering wheel controls sometimes swap and volume changes track or swaps mode and track change does the volume can anyone help with ideas? Cheers in advanced Very Happy
Post #463298 Sat May 30 2015 8:47pm
Timf
United Kingdom 2010 Range Rover Sport TDV8 HSE Galway Green
Interesting, mine does that too sometimes. No idea why but not often enough to warrant a trip to the diagnostics Confused
Post #463313 Sun May 31 2015 9:01am
RRSSte
Yer I sometimes turn it off and it corrects it but would like to stop it doing it really
Post #463319 Sun May 31 2015 9:23am
frostmotorsport
New Zealand 2006 Range Rover Sport Supercharged Rimini Red
it's the wiring loom behind the wheel. They get worn and cause buttons to do the wrong thing etc. Apparently you can remove them and solder them back up as a budget fix. I remember seeing a how-to somewhere, but can't find the darn thing right now!
Basically, pull the battery, unclip the airbag, remove the wheel, fix the loom and reverse the procedure. I'll keep searching... Every home should have one!
'06 RRS SC Rimini Red
'04 Audi S4 Avant
Escort Mk II Sport
Post #463328 Sun May 31 2015 10:01am
RRSSte
oh cheers for that yer if you could find it that would be great 👍bet its a big job then 😒
Post #463330 Sun May 31 2015 10:05am
frostmotorsport
nope. There are two holes on the backside of the wheel - you stick an L shaped bit of wire in there and that unclips the airbag. Remove the wheel (that's the bit I can't remember how) and then remove the loom etc.
Here is the youtube video on removing the wheel....  Every home should have one!
'04 Audi S4 Avant
Escort Mk II Sport
Post #463332 Sun May 31 2015 10:09am
