Home > General > Can these be replaced
Garage Door Medic
United Kingdom 2013 Range Rover Sport SDV6 HSE Santorini Black
Can these be replaced???
They are scratched and look a little bent.
What are they called, I have searched cill plates, but it comes back as another cill plate that covers the painted bits.
Any info appreciated
 MY 13 3.0 SDV6 HSE Black Edition
Santorini Black
Ivory Premium Leather
Side steps
Disklok !!!!!!!
Mud Flaps
Spare wheel protector
Post #456704 Sat Mar 21 2015 8:19pm
You could try searching these L/R Part Numbers LR018086 and LR018089 not sure it's what you are looking for but may point you in right direction. I don't think you can get the name plates separate unless you buy accessory tread plate kit.
Post #456715 Sat Mar 21 2015 10:19pm
Garage Door Medic
Thanks COL for the info, but the bits I am after, are the stainless steel Range Rover bits and the plastic trims they attach to, they run from the front to the rear both sides, been googling inner cill trims and other names, it's going for a service on Friday may see if they can name them MY 13 3.0 SDV6 HSE Black Edition
Santorini Black
Side steps
Disklok !!!!!!!
Mud Flaps
Post #462950 Tue May 26 2015 8:09pm
Paddi
You need to search for sill tread plates and then you can find the originals here:
http://www.rimmerbros.co.uk/Item--i-VPLSS0...tAodGgcARw
Bit pricy mind - suddenly they don't look so scratched now do they Rolling with laughter 2008 MY Java Black TDV8 HSE
Post #462952 Tue May 26 2015 8:19pm
Garage Door Medic
Thanks Paddi, it's not just the stainless Range Rover badg, it's the plastic trim that they sit in as well, passenger door one is not sitting flush to the carpet and the stainless bit is bent, looks like previous owner has for some reason just yanked them up and slightly bent them so I am thinking replace them both sides, MY 13 3.0 SDV6 HSE Black Edition
Santorini Black
Side steps
Disklok !!!!!!!
Mud Flaps
Post #462964 Tue May 26 2015 9:53pm
According to the L/Rs Microcat parts lists the description is Panel, R/H, Inner Lower, "B" Pillar, Tread Plate Stainless Steel, Interior Ebony Carpet. Part Number LR018086 The Name Plate is not listed separately. For the opposite side R/H is simply replaced with L/H. Part Number LR018089.
If you replace them I would suggest you get a few spare clips IPN500090 there are 8 either side.
In my initial post one of the part numbers I appear to have typed 2 instead of a 1
I have just replaced the same thing on my Autobiography and they were £80.00 each so I would imagine they would be slightly cheaper for other variants.
Post #462986 Wed May 27 2015 7:20am
x5pea
Scotland 2010 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Easily replaceable , I swapped the std ones for autobiography ones on my sport.
It's literally a 5 min job.
Post #462991 Wed May 27 2015 8:59am
Garage Door Medic
Thanks Col & X5pea these have been bugging me since I bought it, and been searching for ages, will order with the clips. Bow down Bow down Bow down MY 13 3.0 SDV6 HSE Black Edition
Santorini Black
Side steps
Disklok !!!!!!!
Mud Flaps
Post #463045 Wed May 27 2015 8:22pm
ABSport
United Kingdom 2011 Range Rover Sport 3.0 TDV6 Autobiography Santorini Black
I can confirm the original Autobiography interior side sills Are £46 each side brand new from JLR. I fitted them them to mine brand new Thumbs Up
Post #463049 Wed May 27 2015 8:41pm
Just remembered have a feeling the actually came with new clips fitted but not totally sure.
Post #463054 Wed May 27 2015 9:52pm
Garage Door Medic
Thumbs Up MY 13 3.0 SDV6 HSE Black Edition
Santorini Black
Side steps
Disklok !!!!!!!
Mud Flaps
Post #463142 Thu May 28 2015 10:03pm
Garage Door Medic
Thanks Col, ordered them and fitted them today. These have been bugging me since I got the car, I can't see why they have been damaged, but now they look as they should do, very easy to install, I did order the clips as well, but they came with clips. Thumbs Up Thumbs Up MY 13 3.0 SDV6 HSE Black Edition
Santorini Black
Side steps
Disklok !!!!!!!
Mud Flaps
Post #463987 Sun Jun 07 2015 9:04pm
