| RRSPORT.CO.UK | ||
|  | Home > General > Access mode. |
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9159      | Height sensor playing up by the sound of it. When you try it do you get any red lines showing on the 4x4 display? Will it raise to off road height using the buttons? 2012 SDV6 - it's missing a couple of cylinders
|  Mon May 25 2015 7:59am |
| designboy Member Since: 03 Feb 2014 Location: whitehead co antrim Posts: 338      | Intersting  | ||
|  Mon May 25 2015 3:15pm |
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9159      | The sensors are at on the inner face of the wheel well. You should see the arm and connecting rod quite easily. If you need to change one then you'll also need a calibration doing - can be done DIY with an IID Tool or by someone with another suitable system e.g. LR dealership. 2012 SDV6 - it's missing a couple of cylinders
|  Mon May 25 2015 3:55pm |
| designboy Member Since: 03 Feb 2014 Location: whitehead co antrim Posts: 338      | Cheers, so one of these will do the job (if its broken)
|  Mon May 25 2015 10:38pm |
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9159      | The rear sensors are handed - so make sure you get the correct one for the side that has failed. 2012 SDV6 - it's missing a couple of cylinders
|  Tue May 26 2015 5:58pm |
| Posting Rules
