![]() | Home > General > Rear number plate. |
| sterling01 Member Since: 19 Apr 2015 Location: Kilmarnock Posts: 146
Check out eBay
| fdhadi Member Since: 17 Feb 2015 Location: Wigan Posts: 180
Thanks for that sterling01.
| Frax Member Since: 07 May 2015 Location: Aberdeenshire Posts: 254
I just got a RRS last week from a garage but not main dealer and it was fitted with a 75 style plate, I know they made it as I also had my private plate fitted by them. |
| zaphod Member Since: 16 Jan 2015 Location: UK Posts: 290
This place makes terrific quality plates, exactly the way you want them - make sure you select 'vehicle specific' and then 'Range Rover Sport' in the 'Plate Size' section.
Does anyone know if there is a specific law on plate size? Am I right to assume as long as the text size and spacing if completely legal, the size of the plate is not an issue? My reg is quite short, so I was thinking of cutting the plate down to the bare minimum. Current - 2020 Range Rover Sport P400e
| Ian.H Member Since: 04 Oct 2014 Location: England Posts: 180
That's fine mate and perfectly legal. As long as you keep the padding (edge of lettering to edge of plate) the legal size, you don't have to have more than that.. so 'AB 1' for a plate could be about half the length of a standard plate as an example |
| Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1058
Minimum 11mm gap around the number - top/bottom/left/right
| All times are GMT |
