Home > In Car Electronics > Radio problem
Stephen Dunn
Scotland
Radio problem
I have a problem with my RRS 2005 Radio. Radio works fine, but the only button on the actual radio itself that works is the volume button. Screen appears fine, the only way to adjust the radio is through the steering wheel buttons. Any help on resolving this would be appreciated. Thankyou
Post #462405 Tue May 19 2015 11:55pm
Bodsy
Site Sponsor
Try a hard reset first.
Disconnect the battery cables and touch them together for 10-20 seconds (you may need a spanner or something metal to help reach between them.
Reconnect and try again. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #462407 Wed May 20 2015 12:39am
Stephen Dunn
Scotland
Thankyou. Will give that a try later today after I've finished spraying a van.
Post #462444 Wed May 20 2015 1:38pm
CRACKA
Australia 2006 Range Rover Sport Supercharged Bonatti Grey
Just out and about today in the 2006 RRS 4.2 s/c and I seem to have the opposite problem- no sound and the volumne knob doesn't do anything.
Radio and Cd turn on, display reads etc. Confused Is there some mute button somewhere that disables the sound ? Or should I try the hard reset as well???
Post #468409 Fri Jul 24 2015 10:25am
CRACKA
Further to my last post.
The sound for the radio and hands free phone (bluetooth connection) turns itself on and off for no apparent reason.
Any ideas Question
Post #471053 Tue Aug 25 2015 2:56am
CRACKA
Hello can anyone hear me Question .
As per previous posts but now have lost sound altogether.
Could it be the amp. or something else Question
Does anyone have any Idea
All suggestions welcome.
Post #475435 Tue Oct 06 2015 6:47am
TheWojtek
Seems like an amp failure. The pre-amp in the actual radio/CD unit is unlikely to fail. If turning the volume knob to 11 doesn't make any difference (and there is not even some hiss from the speakers), then you're looking for a replacement amp. Regards etc.,
Wojtek
WAS: 2006 RRS Supercharged
IS: 2010 RRS TDV8 HSE
Post #475444 Tue Oct 06 2015 9:37am
