![]() | Home > General > Few questions from a newbie |
| Camelrock Member Since: 31 Aug 2013 Location: North Yorkshire Posts: 1003
1, check ou Duckworth Land Rover I'm sure I saw them offering some at discounted prices, no you don't need any software upgrades, might need fault codes checking/clearing though.
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9158
1. Cheapest is a compressor refurb kit. Best option is a new AMK compressor. You need to replace the relay when you change the compressor.
| Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477
The software should be updated for an AMK too. "Flack" on here could do this for you. |
I think the software update merely ignores a temperature sensor that the original compressor had and the AMK doesn't have. Apparently it can throw up an error in some cases if not updated. 2012 SDV6 - it's missing a couple of cylinders
It can bring up an exhaust valve fault IIRC. Visiting from DISCO3.CO.UK
Ah, could be that one. I knew there was something like that. 2012 SDV6 - it's missing a couple of cylinders
| All times are GMT |
