| RRSPORT.CO.UK | ||
|  | Home > General > Suspension fault - vehicle lean when cornering |
| Frax Member Since: 07 May 2015 Location: Aberdeenshire Posts: 254      | Have a read of this post it may help
|  Tue May 19 2015 11:59am |
| skirk Member Since: 15 May 2015 Location: Scotland Posts: 4      | Hi,
|  Tue May 19 2015 12:10pm |
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9159      | Could be a faulty ride height sensor, a faulty valve block or one of a number of other issues. Really needs to have any fault codes read to try to pin it down a bit. 2012 SDV6 - it's missing a couple of cylinders
|  Tue May 19 2015 1:37pm |
| Paddi Member Since: 06 Jul 2012 Location: Hertfordshire Posts: 1563      | If the message you are seeing is "SUSPENSION FAULT VEHICLE LEAN WHEN CORNERING" the action you are told to take by Land Rover is to drive slowly and get the fault fixed.
|  Tue May 19 2015 2:01pm |
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9159      | Good spot Paddi, I hadn't read that it was a fault message; I thought it was just the usual leaning suspension issue. 2012 SDV6 - it's missing a couple of cylinders
|  Tue May 19 2015 5:21pm |
| Posting Rules
