![]() | Home > General > Use it or lose it (low-range). |
low range can be selected for anywhere. If you use Rock Crawl, it will lock the centre diff up. It's unlikely that you have a locking rear diff, very few were ever specced with it. |
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9157
As a single motor/mechanism controls Low Range and centre diff lock, selecting Low Range occasionally will probably be enough to "exercise" the overall mechanism. LR's service schedule includes selecting Low Range during the service, presumably to keep it freed up. Whether dealers' technicians bother is a different question, of course. 2012 SDV6 - it's missing a couple of cylinders
| RogerDeFlor Member Since: 28 Mar 2015 Location: Gloucester Posts: 51
OK, thanks chaps. |
To add meat to my previous post, the mechanism for High/Low and diff lock is a combination of a solenoid and a motor. The solenoid is used to select between range change function or diff lock function - default is obviously the diff lock position. Actually, the RRS's diff lock is really a torque biasing multi-plate clutch system rather than a Defender style mechanical lock. This is why the default setting for the mechanism is "diff lock" mode so it can work irrespective of high or low range choice.
Wow, thanks for the explanation |
| sagalout Member Since: 26 Feb 2013 Location: Harrogate Posts: 128 |
Take it out and give it a proper test!
Mine gets used too but has been somewhat less than trouble free... 2012 SDV6 - it's missing a couple of cylinders
That's great post, especially considering your Sport is not that old ! |
Ouch - just read your sig! That's quite a shopping list! |
To be honest I'd prefer a D4 but my wife doesn't like them (despite telling her many times its basically the same car just a bit more practical!) and it's our only car |
| Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477
The D3/4 is not comparable with a Defner; it's very much in the same bracket as the RRS here (it's the same as a TDV6 RRS underneath 2006 Discovery 3 TDV6 Auto HSE Zambezi Silver
yeah, I drove a few, but for some reason the Sport felt better on the road. Even my wife could tell that round bends it didn't bring on any of the slight sea sickness that she felt, even in the Full Fat. Maybe the setup is slightly more road biased, or not being as tall, it doesn't lean as much. |
Yes, there will always be slight differences. The RRS does have slightly firmer suspension - which many fit to their D3s. The condition of the suspension components will also have a great bearing on the ride and handling. Being heavy cars, they eat through bushes quickly. |
I went to Gaydon a few weeks ago and one of their experience drivers was saying that most of the drivers considered the D4 to be the best car that Landrover makes. He did say though that on the RR Sport can go around their tarmac test circle 10mph faster than than the D4. |
| All times are GMT |
