Home > Wheels & Tyres > Wheel spacers
Si-W85
Wheel spacers
I am looking to fit some wheel spacers but I can only find 30mm, now I'm guessing that is because they are studs is this correct? Also will 30mm be too much for the front? I have 20" wheels but unsure on the offset so will post a pic and hope that helps. If anyone has fitted spacers and has a picture that would be great. Thumbs Up
Post #461899 Thu May 14 2015 8:14am
Si-W85
Can nobody on this forum help :/ I can't believe nobody on here has any experience with wheel spacers Big Cry Sheep
Post #462061 Sat May 16 2015 7:43pm
Bodsy
Site Sponsor
I do t have spacers on mine, but have fitted plenty for others. 30mm is the max I'd go with. (Remember it's 60mm overall width increase).
It does make the wheels have a slightly more sure footed stance IMHO. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #462063 Sat May 16 2015 8:19pm
Si-W85
What do they sit like when on Bodsy I think the rears should be ok but don't want the fronts to stick out further than the arches? Thanks for the reply Thumbs Up
Post #462064 Sat May 16 2015 8:24pm
Bodsy
Site Sponsor
Quite a few do 20-25 front and 30 rear just to let it sit differently. Probably 20 front would still be good. Discos wok well with 30 front, but it can look marginally out of the wheel arch( just) Bodsys Brake Bible
See it HERE
Post #462066 Sat May 16 2015 8:33pm
Si-W85
Think I'll get a set of 4 30mm terrafirma and if the fronts sit out too far skim them down to suite. Cheers Thumbs Up
Post #462067 Sat May 16 2015 8:36pm
