Home > Maintenance & Modifications > Gearbox flush in south wales. has anyone done it!
Page 2 of 3 <123>
Williamsboy
Wales 2005 Range Rover Sport TDV6 HSE Rimini Red
Hi Rogerdeflor, Thanks for your reply. I had stumbled accross this thread a while ago. And all my tyres are the same make and size allround. The fault code i have been getting is P0734 "5th gear incorrect ratio" which when you switch off the ignition it clears itself for a while. It could be three or four weeks between issues and then can happen 3 times in a row on the same journey. Gearchange in the low gears is fine, does not seem to kickdown very well and feels like it slips when going into fifth or sixth gear. which is when i get the Fault and Limited gears available on the information panel. Think i have either a solenoid going down on the mechatronic unit and or clutch pack worn. Either way seems to be costly repair.
Mike
Post #461954 Thu May 14 2015 5:10pm
Disco_Mikey
Mine also has an incorrect gear ratio fault, occasionally 4th gear, more frequently in 5th gear.
4th to 5th needs to.be done with minimal throttle input
5th to 6th is very lurchy and clunky
Got bad news for you... Big Cry
Post #461964 Thu May 14 2015 7:12pm
Williamsboy
Hi Disco
I know the bad news is ' its going to cost a small fortune to fix the issue' But i have to look for somewhere to book here in for the work to be carried out. I am going to France this summer and was going to take the RRs on her maiden overseas trip as part of the Family Holiday. Also the bloody EPB has started playing up this week, getting a loud screech from under the RRs when applying the EPB and then getting the amber and red warining lights.
Mike
Post #461994 Fri May 15 2015 11:28am
Hamner
Wales
mega flush
hi mike , real sorry to hear that i wish you the best of luck with it regards danny
Post #462000 Fri May 15 2015 12:09pm
Lost for Words
I believe Bristol Transmissions are quite highly regarded on here. Thumbs Up
Make sure you stop using it before it's too late. Probably just needs an adjustment. Wink Visiting from DISCO3.CO.UK
Post #462002 Fri May 15 2015 1:05pm
RogerDeFlor
Adjust the shoes, as per Bodsy's Brake Bible, that'll save you at least a few shekels. If you've not done it before, don't worry, it's quite easy to do when you get down to it. Thumbs Up
Post #462004 Fri May 15 2015 1:47pm
Williamsboy
Hi guys noticed something odd on my way home from work. Parked on the drive rrs in normal suspension mode, engaged epb and had the actuator / epb squeel/ screech. Dis engaged epb and lowered to access level, re-engaged epb with no screech/squeeling noise. Raised the suspension and tried again and applied epb to be met by the screech/squeeling noise. Lowered rrrs and no noise when epb engaged.
May take the opportunity to look for a wiring fault over the weekend, read somewhere that one owner found a chaffed wire near the n/s/r wheel arch area. Weekend of work spent under the rrs. No rest for the wicked. Twisted Evil
As for the gearbox will probably take it back to the people near Cardiff who did the gearbox service, they are a zf specialist, but have read good things about Bristol transmissions too.
Cheers all
Mike
Post #462007 Fri May 15 2015 2:55pm
Lost for Words
The EPB screech won't be a wiring fault. What you're seeing is probably related to the change in geometry when lowering the car. Thumbs Up
Just don't let it screech any more or you will be looking at a new module. Wink Visiting from DISCO3.CO.UK
Post #462009 Fri May 15 2015 3:11pm
Williamsboy
Cheers lost for words. Just thought it was a bit odd that's all.
Mike
Post #462011 Fri May 15 2015 3:19pm
Hamner
Wales
mega flush thread
hi guys , just doing some more research on amega flush does anyone know what difference the zf fluid makes as to other transmission fluids as there is a lot of difference in cost cheers Thumbs Up
Post #462107 Sun May 17 2015 2:22pm
Lost for Words
Using the correct fluid is certainly very important. It's not something I'd take any risks with. Thumbs Up Visiting from DISCO3.CO.UK
Post #462111 Sun May 17 2015 3:06pm
Williamsboy
Hi all just an update on the gearbox issues. Towed the tin can to the gower this week and transmission fault happened on four occasions. Did exactly the same on the way home a few days later. RRS going in tomorrow for gearbox strip Big Cry I know its going to cost a small fortune to fix but got to go ahead with it now. Oh and roger I did check my tyres and guess what I had one rear tyre of a different make, and when I measured the two together there was at least a 3/8" of an inch difference in circumference. But alas this find did not alter my problems with my transmission mores the pity.
Thanks everyone for your input and good advice, always appreciate help in any form. Never be afraid to ask, that's what I was taught as a young apprentice mechanic and what I teach to apprentices in the aviation industry everyday. ( there's no hard shoulder to pull into at 30,000 feet!)
Many thanks
Mike
Post #465763 Thu Jun 25 2015 10:28pm
Williamsboy
Many thanks
Mike
Post #465764 Thu Jun 25 2015 10:28pm
DrRob
Did you get it sorted? * Current: 2024 D350 Defender 90 on coils!
* Current: 1974 Lightweight 2.25L petrol. Old skool
* GONE: 2012 RR Sport HSE SDV6 Orkney Grey. Now being piloted by RRSTDV8
I use www.glenrands.co.uk Great independent specialist!
Post #466029 Mon Jun 29 2015 4:09pm
Williamsboy
Hi DrRob, RRs is in the Garage with the Gearbox dismantled. Box is Knackered! the garage have sourced a Reconditioned Gearbox with 2yrs unlimited mileage warranty for me. so not sorted as yet but on the right road.
Total bill will be close to £3000, but hands are tied and have to go ahead and replace gearbox. at least i get some peace of mind from the 2yr warranty.
Mike
Post #466109 Tue Jun 30 2015 9:07am
Page 2 of 3 <123>
