Home > General > Handling issues
needle
Handling issues
Hi all, A question about my 2005 range rover sport superchargeds handling..its awful !!! it gets itself all uspet if breaking or cornering at the slightest corner at speed,above 50 , I had a 2003 range rover vogue and this handled fantastic,this sport is awful is all over the place on corners and gets real twichy , I have a transit van that out handles this sport 10 fold over .( , the traction control light will flash quite often when cornering , there must be something wrong as its done this since i got it ,,Im not a sprited driver ethier , any suggestions where to look for possible reasons ? no fault codes com up on the IDD tool .thanks inadvance
Post #461941 Thu May 14 2015 4:17pm
JSR2014
England 2013 Range Rover Sport Supercharged Santorini Black
What tyres are you using? 2014.5 Mariana Black 5.0 Supercharged V8 Autobiography
Post #461942 Thu May 14 2015 4:19pm
needle
It had standard tyres /wheels on before,cant remember which ones tbh but now got 22s on and cant remember the tyres.... it was the same with both ,
Post #461943 Thu May 14 2015 4:23pm
needle
I took the wheels off my old rangie and that handled amazing with the wheels and tyres
Post #461944 Thu May 14 2015 4:24pm
You fitted Vogue wheels and tyres to your Sport? Was this before or after you experienced the poor handling? 2012 SDV6 - it's missing a couple of cylinders
Post #461953 Thu May 14 2015 6:02pm
needle
it was aftermarket alloys that fitted both , it handled like a boat before the wheels where put on so not the wheels , Just had to get different bolts if i rememeber , it was from a specialist alloy wheel place
Post #461955 Thu May 14 2015 6:12pm
Sounds like you have a mechanical failure somewhere as it shouldn't be boat-like in its handling. It's certainly got better handling than a Vogue which is usually described as being boat-like. Is it still on its original suspension bushes etc.? Is the Dynamic Response system in good shape? What about the dampers - are they original? 2012 SDV6 - it's missing a couple of cylinders
Post #461960 Thu May 14 2015 7:13pm
needle
Tbh I don't know ,only had the car about 9 months , what would you recommend getting changed ? There's no codes coming up so I'm assuming bushes would be a good start .thanks
Post #461961 Thu May 14 2015 7:17pm
First get the suspension alignment properly checked and adjusted. Then worry about changing things... 2012 SDV6 - it's missing a couple of cylinders
Post #461972 Thu May 14 2015 10:42pm
JSR2014
Check tyre pressures too - also check that you've not mixed brands.
Dont the vogue and RRS have different offsets? 2014.5 Mariana Black 5.0 Supercharged V8 Autobiography
Post #461985 Fri May 15 2015 10:19am
I'd be surprised if the wheels/tyres from the Vogue are helping the issue but he says it was bed before the change of wheels.
It sounds like something is worn out or that there is a speed sensor telling the DSC that it's spinning etc. Something like that will make the system try to straighten the vehicle and that can feel pretty unpleasant if you don't actually have a traction issue in the first place. 2012 SDV6 - it's missing a couple of cylinders
Post #462026 Fri May 15 2015 8:26pm
tailormadefun
United Kingdom 2006 Range Rover Sport Supercharged Zermatt Silver
I had a similar problem with my 2005 SC when I got it, it was knackered wheel bearings, 450 for both sides now she tracks straight and true, and it got rid of the wheel wobble at motor way speed, jack the front up and grip the wheel at 12 and 6 and move it back and forward, if there's a lot of play there's ur issue
Post #462037 Sat May 16 2015 8:15am
