| RRSPORT.CO.UK | ||
|  | Home > Maintenance & Modifications > MK 1 RRS front bumper lower spoiler listed on Ebay |
| vam17hel Member Since: 19 Mar 2015 Location: North Yorkshire Posts: 30      |
 Has anyone out there fitted the front bumper spoiler on ebay for the mk1 RRS, if so do they fit with min mods or are they a country mile out i dont mind a bit of triming but there is a limit   | ||
|  Sun Apr 26 2015 2:44pm |
 Finally took the plunge and bought this spoiler this morning ,should be here wed/thur this week so i will check it out and start fitting at weekend hopefully and report on progress and quality. | ||
|  Mon May 11 2015 2:04pm |
| jmcvs Member Since: 26 May 2014 Location: Glasgow Posts: 173      | Vam, try and take some pics of this when you are fitting it if you don't mind   | ||
|  Mon May 11 2015 2:37pm |
| vam17hel Member Since: 19 Mar 2015 Location: North Yorkshire Posts: 30      | Will do no problem  | ||
|  Mon May 11 2015 2:48pm |
 Some photos in my albums of the job so far and more to come.Now for paint   | ||
|  Fri May 15 2015 5:22pm |
| darrenmcneill Member Since: 05 Oct 2014 Location: Whitworth Posts: 442      | How easy was the fit? I emailed the seller who said they just fit over the existing front splitter?
|  Fri May 15 2015 5:36pm |
 Not a bad job to fit needed some reshaping on corners and glued along top edge and screws along under side.you need to remove the two rubber spliters and as they get in the way,i also `left of towing eye cover as you would not be able to remove afterwards in a breakdown.The parking sensors were the hard bit i have drilled a hole just a snug fit for sensor only and not surround as the shape is all wrong but you will need to remove bumper to refit them hope this helps you .  | ||
|  Fri May 15 2015 5:46pm |
 Finally got to finish of job and found time to get in colour
|  Sun May 24 2015 12:13pm |
| ABSport Member Since: 14 Aug 2014 Location: Plymouth Posts: 698      | That looks nice   | ||
|  Sun May 24 2015 12:35pm |
| jmcvs Member Since: 26 May 2014 Location: Glasgow Posts: 173      | Nice job   | ||
|  Sun May 24 2015 1:16pm |
| vam17hel Member Since: 19 Mar 2015 Location: North Yorkshire Posts: 30      | Thanks it was well worth the work  | ||
|  Sun May 24 2015 1:39pm |
| Posting Rules
 .Also was there any probs with or refitting front parking sensors. Thanks for any advice before i buy.
