Home > In Car Electronics > Head Unit led lights not working...
Guyzer73
Oman 2006 Range Rover Sport Supercharged Vesuvius Orange
As the title says when I turn on the side/ headlights the stereo head unit led back lighting doesn't work.
I've tried turning the adjuster dial by the headlight switch and all other lights dim and brighten as they should but the HU leds stay resolutely off. Evil or Very Mad
I pulled the head unit and checked the ribbon cables from the main pcb to the pcb located in the fascia but all seems in order as all other functions work. I also visually inspected the fascia pcb and couldn't find any obvious damage or burn marks.
Also the back lighting to the info screen on the head unit dims and brightens as it should when the lights are switched on.
Basically at a loss what could be causing this...
Does anybody have any ideas??
Flack maybe?? Wink
Thanks in advance.
Guy 2006 RRS S/C CONSTANTLY under modification...
1994 RRC 4.2l not LSE sadly gone but not forgotten
LR Defender 300Tdi - affectionately know as "The Black Beast"
Post #458613 Wed Apr 08 2015 7:33pm
Burns
United Kingdom 2006 Range Rover Sport TDV6 HSE Zambezi Silver
Is your battery getting low as mine did this the other day. Result it'sjust had a new alternator fitted :
Big Cry Diesel sport BAS remapped by Bodsy
390 Bhp SLK 55 AMG
H D Softail Slim Milwaukee 8
I like ā€œV’sā€ šŸ˜Ž
Post #461508 Fri May 08 2015 11:32am
Guyzer73
Hi Burns,
Thanks for the tip Thumbs Up
However I found the problem after stripping down the HU. Obviously at some point a single strip on one of the ribbon cables had doubled over. Once I carefully folded it back flat and reinserted it all good.
Post #461695 Sun May 10 2015 5:51pm
