![]() | Home > In Car Electronics > ENGINE FAULT !?! |
Could be various things including EGRs, turbo, turbo actuator, turbo hose, fuel pump/filter...
andrew kennedy Member Since: 27 Apr 2010 Location: brittany Posts: 346 ![]() ![]() ![]() |
Thanks for yours!! Would the problem be shown up using a diagnostic tool? Or is it the case of looking for the answer to the problem by elimination? Grateful for your comments!! Andrew Kennedy |
Sorry I wasn't able to reply sooner. Yes, fault codes and live data from a diagnostic tool will be able to reveal the issue in many cases, or at least give a pointer in the right direction. |
pollawyn Member Since: 07 Dec 2015 Location: cornwall Posts: 19 ![]() ![]() ![]() |
Can an intermittent fault be recovered by the diagnostic tool. I ask because I have experienced the occasional fault message accompanied by loss of power, switching off and restarting has resulted in normal service being resumed. |
Yes, fault codes have various different states, so historic faults can still be seen. |
I have had exactly the same experience. Due I am told because I have not been using the engine to anywhere near is full potential - basically the exhaust fumes have gunged up a few sensors. You need to consult a garage who knows the workings of Land Rovers who would sort the problem out. Andrew Kennedy |
I have a 2006 4.2 supercharged. Engine fault light, I have been told likely to be EGR, have also been told no ESG on petrol engines. Definitive answer please and if EGR present where can I get same. Otherwise magnificent chariot, I smile every time I get in and smile even broader when that engine fires up, who needs a radio. |
