![]() | Home > General > bonnet Washer jet monkey BABOONS ripped out. HELP |
ABSport Member Since: 14 Aug 2014 Location: Plymouth Posts: 698 ![]() ![]() ![]() |
OMG |
newlove2003 Member Since: 16 Apr 2015 Location: west yorkshire Posts: 24 ![]() ![]() |
yeah mate i am, only had the rrs for about 1 month. i found water jets on flee bay , but wondering why the dab as gone off or at least most of the stations. anyone have a helping hand fitting the water jets back to the bonnet and the tubing? anyone no how to rewire the dab aerial but still not sure if that is the cable what came out and there is 1 left. the wire where only a few inches long i think. |
Mate the washer jets just clip back in and the water pipes just push in. Not sure about the electrical cables as they are heated but assume they have a plug attached. As for the DAB I can't see why that is affected. As the DAB Ariel is standard in the rear side windows and the dab module inside the boot. |
cheers for that, ill double check the dab radio again, how do i get that fabric cover on the underside of the bonnet ? thank you |
hse-lee Member Since: 17 Jan 2015 Location: london Posts: 77 ![]() ![]() ![]() |
It's clipped in with round black clips just remove them and the fabric will be able to be removed. Once removed you'll be able to see the cables ![]() |
thank you for your help, yeah i just retuned my dab radio had nothing to do with the baboons, ordered the parts from range rover 35 pounds not bad at all. got a new issue now as i can see the rear window wiper is not in its correct place when it turned on, anyone no how to adjust this please thank you |
zaphod Member Since: 16 Jan 2015 Location: UK Posts: 290 ![]() ![]() ![]() |
I bet the next time the suns shines on your bonnet you'll notice a few new problems (scratches). I had the exact same problem when I took my last car through the baboon enclosure... I even tried spraying the washer fluid out to deter them but they seemed to like it and were drinking it!!! |
URX Member Since: 09 Feb 2009 Location: Edinburgh Posts: 194 ![]() ![]() |
this is what chaepo bangers are for
Gornal Hills Member Since: 10 Nov 2014 Location: Dudley Posts: 380 ![]() ![]() ![]() |
HI, this happened to me a few years ago at our local safari park, the little monkey decided to remove the wiper arm and blade off my Peugeot van |
Unfortunately I think the apes, monkeys etc have become so used to cars in the enclosures they have learnt the tricks which do damage.
Nik Member Since: 19 Nov 2010 Location: Up North Posts: 657 ![]() ![]() ![]() |
Madness to take a decent car through a monkey enclosure, seen the result many times on you've been framed. 2015 Golf R DSG
whippetman Member Since: 12 Jun 2010 Location: on the level Posts: 502 ![]() ![]() ![]() |
Can't believe you'd do this in any thing that you care for |
well got the washer jets getting fixed tomorrow also noticed a very small dent on the bonnet the hairy red arse b***ards, got a guy coming Thursday to get that fixed, i feel like crying still lol dont worry lads ive made her make up for it lol |
