Home > General > sat nav disc
orangevanman
sat nav disc
i have a 2007 rrs which i believe is still running the standard nav disc, i am not too sure what to buy or even how to change it but is this the correct disc i am looking for?
also how do i know if mine is a denso satnav?
http://www.ebay.co.uk/itm/Land-Rover-Range...25a550e6e9
if it is how do i change it please
Post #460669 Tue Apr 28 2015 1:05pm
Bodsy
Site Sponsor
you move the passenger seat all the way forward and all the way up.
then go behind the passenger seat, reach under and over the top of the box, right hand side is a button. if it doesnt click, go to the left hand side and slide the catch, then go back to the right hand side and press the botton. Disk shoiuld eject out, put new disk in.
dont forget to change the region to UK instead of Belgium when you go back to entering a destination. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #460672 Tue Apr 28 2015 1:16pm
orangevanman
thank you bodsy, does that disc look ok? is it the correct one?
is it a put in and play thing , no need to set it up etc?
Post #460680 Tue Apr 28 2015 2:58pm
jimbg
Just put it in and wait........and wait...... takes a while but nothing to do.
When it is finished the default country will be Belgium and you need to change it to the UK.
Looks like the right disk to me. 2023 P440e SE Dynamic on order -cancelled
2022 HSE Dynamic P400e
2006 HSE
Post #460682 Tue Apr 28 2015 3:18pm
orangevanman
Can someone pls talk me through how to change the disc. I know where the disc goes but how do j actually change it??
Do I have the ignition in? Or the engine running? Or no keys in?
Post #460903 Fri May 01 2015 11:32am
Lost for Words
Ignition on (don't think it matters if the engine is running). Same as any other DVD but with the addition of a lock button on the drive. Thumbs Up Visiting from DISCO3.CO.UK
Post #460905 Fri May 01 2015 11:59am
orangevanman
all done wow that was easy, dont see any distinct changes to the screen though or is it just updated roads?
Post #460907 Fri May 01 2015 12:44pm
Lost for Words
Basically, just the roads. Thumbs Up Visiting from DISCO3.CO.UK
Post #460909 Fri May 01 2015 12:48pm
orangevanman
thanks guys for the help
Post #460910 Fri May 01 2015 1:06pm
