| RRSPORT.CO.UK | ||
|  | Home > General > At last, I've got one. |
| Timf Member Since: 27 Feb 2010 Location: East Anglia Posts: 312      | ......when jacking and placing stands, make sure you avoid the compressor - I've nearly put the jack there which would have been expensive  | ||
|  Mon Apr 27 2015 3:05pm |
| Bodsy Site Sponsor Member Since: 03 Feb 2007 Location: Shropshire Posts: 2162    | Well done Roger, i love the 'any errand I can invent to drive it'   | ||
|  Mon Apr 27 2015 3:37pm |
| RogerDeFlor Member Since: 28 Mar 2015 Location: Gloucester Posts: 51      | Bodsy, "wilco" on the QuickLift jack, I noted your note in your PDF about it. Thanks again for that.   | ||
|  Mon Apr 27 2015 7:00pm |
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9159      | There is a jacking point between the rear wheels in front of the spare wheel - there's a hole in the cross frame. The only problem is that the spare wheel gets in the way and the point is a long way up so you end up raising the jack on blocks before lifting. 2012 SDV6 - it's missing a couple of cylinders
|  Mon Apr 27 2015 7:40pm |
 You can do it one side at a time, no problem. You just need to chock the front wheels, set the EPB as per the bible & remove the fuse, then put the car in Neutral (best done by using the emergency gear release. On the Disco (same as RRS, but I'm not 100% sure if you have the same piece of plastic, but the release will work if you can get to it) so on the Disco, behind the EPB switch, is a flat plastic piece, that can be removed by levering it up. Then put your middle finger from your left hand in the hole and point it towards the D on your gear lever selector. Have a wiggle around and yoiu will find a piece of plastic that you can just push up on, that releases the gear lever so you can put it in Neutral without having to put the key in the ignition. Then jack up the side you want to adjust. Personally, If lifting one wheel, I tend to use the lower wishbone as it takes less effort. The right and proper way is the jacking point holes in the chassis You can also use this trick if you have no power and need to be recovered, it saves the recovery guys having to drag your 2.5t vehicle up their ramps and possibly damaging the park pawl in the gearbox. Bodsys Brake Bible Software Updates Contact me RRS Timed Heat/Remote kits - Contact me BAS Engine Re-maps/ EGR Blank EuIII and EuIV Clock On The Dash/ SNOTM /3Flash / BT Update /Service Reset/Error Codes read\ Gearbox Reset See it HERE | ||
|  Tue Apr 28 2015 9:00am |
| sterling01 Member Since: 19 Apr 2015 Location: Kilmarnock Posts: 146    |
 Interesting Bodsy. A few others on this forum have bought one of these. Is there a known issue? They are rated for 3 tonne so should be fine for an RRS. What jack would you alternatively recommend? | ||
|  Tue Apr 28 2015 10:42am |
| Bodsy Site Sponsor Member Since: 03 Feb 2007 Location: Shropshire Posts: 2162    | the same brand jack is fine, but NOT the quicklift one. If your car moves (as is likely) whilst being jacked up, the trolley can twist. The quick part comes at a cost of rigidity.
|  Tue Apr 28 2015 10:56am |
| Posting Rules
