| RRSPORT.CO.UK | ||
|  | Home > General > Rear roller blind |
| Morepower Member Since: 26 Aug 2014 Location: Somerset Posts: 13      | Anyone😩😩😱😱 | ||
|  Mon Apr 27 2015 8:25pm |
| Paddi Member Since: 06 Jul 2012 Location: Hertfordshire Posts: 1563      | Sometimes no-one knows the answer which is probably why there have been no other replies.
|  Tue Apr 28 2015 1:41pm |
| Russben Member Since: 27 Mar 2013 Location: Lancashire Posts: 278    | I retensioned mine when a screw came loose. I just wound the blind backwards until the spring resistance felt tight enough & then pushed the end cap back on & tightened the screw back up again. It wasn't too difficult. I'm in the shed, I'll be back in the real world in a minute.
|  Wed Apr 29 2015 11:48am |
| mr_spaceuk Member Since: 26 Apr 2015 Location: Berkshire Posts: 40      | Mine has also gone loose, and so I'm going to give this ago too. | ||
|  Wed Apr 29 2015 7:40pm |
| AlanEricThompson Member Since: 14 Oct 2013 Location: Nuneaton Posts: 96      | My blind tension is ok, but the end cap that is spring loaded is loose. This causes the whole thing to rattle as it is not fitting tight enough, it drives me MAD when I have a squeak.
|  Thu Apr 30 2015 11:54am |
| Russben Member Since: 27 Mar 2013 Location: Lancashire Posts: 278    | Tighten the screw up again & check the boot side panel trims are secure. Aparently the plastic retaining clips can break in the side panels if a dog guard has been fitted and that can cause a rattle/squeak (the dog guard pushes the trim panels outwards & breaks the clips).
|  Sun May 03 2015 8:31pm |
| bossman115 Member Since: 27 Aug 2016 Location: essex Posts: 8      | I have stripped my blind right down and re-tensioned the springs but I am stuck on how to hold the tension whilst trying to locate the stupid grub screw on the end and line it up to the centre bar. After 3 hours and loads of blue air I give up! | ||
|  Tue Jul 11 2017 7:42pm |
| Posting Rules
