![]() | Home > Maintenance & Modifications > Power steering leak |
MJ87 Member Since: 04 Jan 2015 Location: South Yorkshire Posts: 63 ![]() ![]() ![]() |
Could somebody please identify this leak? Power steering reservoir has dropped about an inch below minimum over the last month.
Cheers RRSTDV8.
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9148 ![]() ![]() ![]() |
Not sure the valve is a serviceable item. The transducer is but that's an electronic item on the rack that controls the valve.
Thanks,
If it's leaking then I suppose it could cause the notchy steering because the moment it leaks will result in less power steering effect. 2012 SDV6 - it's missing a couple of cylinders
I managed to get it looked at by a garage this afternoon.... they reckon the UJ is causing the notchy and stiff steering and needs replacing which doesn't surprise me.
Garage has got back to me saying they have been told that a full steering rack is required for a total cost of £1500 |
My steering rack was replaced under warranty and the price noted on the paperwork is £1173. That is excl VAT but I assume includes labour. There was a surcharge on the part - presumably it's an exchangeable unit. That was at a main dealer.
Bit of good news...The leak has been fixed |
Excellent news. I wasn't sure the rack was serviceable but it obviously is in part. A great outcome. |
Cheers for your input on the subject RRSTDV8 |
I had a new power steering pump fitted under warranty a few weeks ago. I think it's a good couple of hours' work. 2012 SDV6 - it's missing a couple of cylinders
