![]() | Home > General > Car lowering itself after parked |
mlines Member Since: 10 Dec 2006 Location: UK Posts: 480 ![]() ![]() |
Is your driveway level? 2016 RRS 4.4 TDV8 Autobiography Dynamic in Montalcino Red and Stealth Kit |
D12TYJ Member Since: 01 Sep 2014 Location: London Posts: 183 ![]() ![]() ![]() |
Yep, flat & level as anything. |
Well mine levels itself off as you describe but is just as likely to be the front depending on the situation 2016 RRS 4.4 TDV8 Autobiography Dynamic in Montalcino Red and Stealth Kit |
zaphod Member Since: 16 Jan 2015 Location: UK Posts: 290 ![]() ![]() ![]() |
Mine does it too - it's usually the OSF that drops down with a bit a whooshing sound. Freaked me out at first but now I know it's just compensating for being 16 stone lighter on that corner when I get out |
Hmmm...
Chin Member Since: 02 Sep 2013 Location: London, UK Posts: 66 ![]() ![]() ![]() |
I'm not an expert my any stretch of the imagination but if it were me I'd be suspecting an air leak from my rear suspension |
How could i check this? |
Remembering from past topics on here you should have a play with putting the suspension into 'off road' height and seeing if you get any errors such as 'car rising slowly' or something similar.
ziglo Member Since: 20 Feb 2015 Location: channel islands Posts: 19 ![]() ![]() |
Yep I would say it's a sensor that's gone wrong, book it in with a good mechanic who has the proper software to run it and diagnose the fault. |
I'm pretty sure I've read that if you park up and disconnect the battery (or pull the appropriate fuses) and the car still lowers then you have a leak... However if it no longer drops then you have a sensor/electronic problem that causes the car to erroneously adjust the height to keep the car 'level'. |
Pull Fuse 26, IIRC. |
martyn05 Member Since: 13 Feb 2014 Location: Derby Posts: 324 ![]() ![]() ![]() |
Reverse onto your drive and see if the rear still lowers? 2006 RRS SC Bonatti Grey (the 55th car/van I have owned)
