Home > General (L494) > Wheel Centre Caps
Tim in Scotland
Wheel Centre Caps
Before I start digging with a screw driver and ruining them, does anyboy know if the plastic wheel centres can be removed without jacking the car up and taking the wheels off? I have a set of Range Rover centre caps that look much nicer than the LR green ones fitted to my car. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #459364 Thu Apr 16 2015 10:01am
Renaco
the idea is, the centre caps are only easy to remove when the wheel is of, as otherwise they are to easy to grab by others... Evil or Very Mad
i tried on several cars, but without scratches you cant remove them from outside, only if you design a special tool for it... Wink
Post #459375 Thu Apr 16 2015 11:55am
richamartin
2013 Range Rover Sport 4.4 V8 Baltic Blue
I find that a small flat head screwdriver will remove them easily without any detrimental effects.
Just go carefully and lever them off.
I did exactly the same change! Now
2022 SVR
2021 Bentley Continental GT
2020 Defender 110
2022 Defender 90 V8
Plus 16 other toys! Wink
Post #459378 Thu Apr 16 2015 12:39pm
Chrisr1806
Tim,my ours has green centre caps? They should be silver... Arrived: MY16 A/B SDV6 in Aruba, Ivory interior, piano black trim, black panoramic roof, spare wheel, blind spot monitoring, mudlaps and more... Twisted Evil
Gone but not forgotten:
2014 RRS2 SDV6 HSE in Loire Blue
2011 Freelander 2 SD4 HSE in Santorini Black
Post #459379 Thu Apr 16 2015 12:54pm
drdelrrs
use a plastic sucker like you get on kids toy arrows or for mounting stuff on windscreen; quick clean easy and no damage !!!
Post #459384 Thu Apr 16 2015 2:22pm
Dave777
That is probably what Land Rover's special tool is!! And £100 labour!
Post #459392 Thu Apr 16 2015 4:19pm
Tim in Scotland
Chris, just checked and yes mine are silver too, I have the caps from the winter wheels I bought for my Evoque and will be putting them in in place of the plain jane silver ones. Thanks for all the tips - will start with the sucker, graduate to the flat head screw driver and then as a last restort take the wheels off, but that sound like a lot of work on a hot evening........... when I should be having a cooling beer. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #459393 Thu Apr 16 2015 4:29pm
Mark_N
Don't use a screwdriver, you will mark the wheel. Use a plastic pry-tool instead. Far better though to remove the wheel. Mark
SVR in Estoril Blue Thumbs Up
Post #459418 Thu Apr 16 2015 8:48pm
kbklr
+1 for the sucker method - valve grinding tool with a smear of grease
Post #459576 Fri Apr 17 2015 8:59pm
harrygh60
England 2010 Range Rover Sport 3.0 TDV6 HSE Fuji White
My centres were U/S,as the paint had flaked off because power hose use. Big Cry Big Cry So as not to damage wheels. I drilled a small hole in the centre cap and screwed in a srew then just pulled them off Thumbs Up itisme
Post #459655 Sat Apr 18 2015 2:22pm
