![]() | Home > General > Testing out the RRS for first time |
Si, your RRS S/C should have the Dynamic Handling pack which the TDv8 also had and was optional on the 2.7HSE. The DP system will allow the rear ARB's to dislocate electro-hydraulically and permit additional wheel extension over standard anyway! Your father was right, and your S/C will be the same as you have the Brembo larger brakes and the smallest OEM wheels that would fit over the calipers would be one of 2 designs - there is another thread where I posted a photo of the Goodyear MTR's mounted on one of the designs and another member also posted a picture of the other design that he has on his TDv8. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9151 ![]() ![]() ![]() |
Removing the steps is fairly simple - about an hour if you're handy. Whether it would be worth taking them off and replacing them each time is moot.
Si-W85 Member Since: 22 Mar 2015 Location: Huddersfield Posts: 109 ![]() |
Thanks for all the input I'm constantly learning from this forum |
In fairness, I think the half shaft issue occurs naturally because the inner end isn't actually fixed in to the diff - it's not a problem only with the Mudtech system.
That's interesting about the Grabbers I could be tempted for a set of those especially when the shooting season starts (winter) I know the 19" will be better due to bigger tyre wall but I like the 20" wheels lol agreed with the steps I noticed they took a bit of stick when I had the RRS bellied with the wheels spinning lol managed to drag myself over the hump on the steps almost 3 tonne on top of some light ally steps is t too bad but yes they do hang too low compared to the discos |
