| RRSPORT.CO.UK | ||
|  | Home > Technical > Coolant Leak , but not during operation |
| Paddi Member Since: 06 Jul 2012 Location: Hertfordshire Posts: 1563      | Hi, it won't be the intercooler as this is just for cooling the air going into the engine and should only contain air (although there is usually a little oil from the crankcase breather too).
|  Sun Apr 12 2015 6:30pm |
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9159      | Paddi, the S/C intercooler is an air/liquid system not an air/air system like the diesels. The intercoolers sit either side of the supercharger on top of the engine. The intercoolers have a dedicated radiator in front of the engine cooling radiator and there is an electrically driven pump. 2012 SDV6 - it's missing a couple of cylinders
|  Sun Apr 12 2015 9:01pm |
| USAFBuckeye Member Since: 24 Feb 2013 Location: Il Posts: 60      | Thanks gents.
|  Sun Apr 12 2015 10:22pm |
| Paddi Member Since: 06 Jul 2012 Location: Hertfordshire Posts: 1563      | Apologies for the mix-up as I hadn't noted your RRS was a S/C.
|  Mon Apr 13 2015 1:27pm |
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9159      | The intercooler radiator is the smaller, front one, the air con is the middle one and the engine cooling radiator is at the rear. 2012 SDV6 - it's missing a couple of cylinders
|  Mon Apr 13 2015 6:29pm |
| USAFBuckeye Member Since: 24 Feb 2013 Location: Il Posts: 60      | Too right gents.  Today I borrowed a pressure tester and discovered that the radiator is indeed holding ~22 psi for over 5 minutes.  I can still see coolant dripping from what I think is the charge air cooler radiator.  That's the one that sits between the engine (large) radiator, and the intercooler (about half the size of the engine radiator), right?
|  Tue Apr 14 2015 12:54am |
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9159      | I believe the smallest rad is the air charge cooler (intercooler) circuit. The medium sized rad is the air con circuit and the largest rad is the engine cooling circuit.
|  Tue Apr 14 2015 8:34am |
| USAFBuckeye Member Since: 24 Feb 2013 Location: Il Posts: 60      | You might be right.
|  Tue Apr 14 2015 2:06pm |
| USAFBuckeye Member Since: 24 Feb 2013 Location: Il Posts: 60      | Ok, so it's the intercooler.  Dealer diagnosed this morning. Also needs a new expansion tank and sensor...  It's gonna be a pretty hefty bill I have a feeling.   | ||
|  Wed Apr 15 2015 1:39am |
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9159      |   | ||
|  Wed Apr 15 2015 5:51pm |
| USAFBuckeye Member Since: 24 Feb 2013 Location: Il Posts: 60      | Too right!!
|  Wed Apr 15 2015 6:21pm |
| USAFBuckeye Member Since: 24 Feb 2013 Location: Il Posts: 60      | $954 later and my S/C is back in commission.
|  Thu Apr 23 2015 1:28am |
| Posting Rules
