![]() | Home > In Car Electronics > hdc fault again |
Still more stuff with potential - Steering angle sensor or ABS sensor. |
ouchie Member Since: 09 Nov 2014 Location: ayrshire Posts: 20 ![]() ![]() ![]() |
ok lost for words will be at my local 4x4 guy on sat will get that checked thank you |
cossiedave Member Since: 20 Jun 2012 Location: lancaster Posts: 882 ![]() ![]() ![]() |
might be worth pulling conector on abs pump, give it a good squirt with contact cleaner then plug it back on |
ok will try these things at weekend |
Fish Member Since: 29 Jan 2014 Location: Glasgow Posts: 60 ![]() ![]() ![]() |
I had this fault with mine too for about 6 months, would reset when it went to sleep. This escalated to full Xmas tree dash with hazards and door locks going and no ignition. Had the Central Junction Box changed out and it sorted the Xmas tree dash but still getting the alarms you are getting. I then got the steering angle sensor changed out and that sorted it but what I would say is that I did notice that the alarms your getting, I would only get them when driving A & B roads, car parks and slow manoeuvring, i.e. when giving the steering angle sensor a workout. Hope this helps ![]() |
Fish, the difference with yours was that you had the indicators of a CANBUS problem, but as ouchie hasn't actually specified otherwise, you raise a valid point.
darrenmcneill Member Since: 05 Oct 2014 Location: Whitworth Posts: 442 ![]() ![]() ![]() |
I had the same fault, ended up being a weak battery. Replaced it this week and 'currently' no faults at all....
mnk Member Since: 25 Nov 2013 Location: United Kingdom Posts: 231 ![]() ![]() |
Darren - Which battery did you install? |
http://www.tayna.co./EA1000-Exide-Premium-...P7488.html
Don't forget the D2BOYS discount code - shaves off a few more pounds. |
Now you tell me about the discount!!! Dohhhhh!!!!
Would you pay the extra £14.88 for a Varta with 5 year Guarantee, 110Ah and 920A CCA?
I'd stick with the Exide. They're very well proven to be an excellent battery with many exceeding the specified CCA. |
lol... dont worry about it!
