![]() | Home > General > Flat Battery.... Charging at 15.1v...? Regulator Fault...? |
Yep, as per my post on the other thread: http://www.rrsport.co.uk/forum/post458690.html#458690 |
darrenmcneill Member Since: 05 Oct 2014 Location: Whitworth Posts: 442 ![]() ![]() ![]() |
Noticed the last few days that I'm occasionally getting the "low battery" symbol popping up on the stereo. This only seems to be when I've been using my iPhone and Aux-in.
I would certainly be keeping an eye on the alternator and checking for a battery drain. |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9090 ![]() ![]() ![]() |
Low power on the radio when the engine is running points to a low battery. You do need to check the battery when cold (first thing in the morning or at least 4 hours after last run) and also the alternator output (voltage whilst engine running basically). 2012 SDV6 - it's missing a couple of cylinders
My worry is that the battery is brand new, and I've had the message.
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4505 ![]() ![]() ![]() |
I will wade in here. I don't think you have an issue |
Cheers Mike, appreciate that post!
