Home > General > BATTERY - parking problem
andrew kennedy
France 2006 Range Rover Sport TDV6 HSE Maya Gold
I have a 2009 Sport. A new battery was fitted 12 months ago approx. I need to park-up at an airport for possible eight weeks and I think I could have a problem!! I have noticed parked and locked in the garage, the battery needs charging about every 4/5 weeks to keep it in good order for starting. Any tips about leaving the car for a long period of time and finding the battery ok on my return? Andrew Kennedy
Post #458674 Thu Apr 09 2015 12:37pm
jeffhunt
get a solar charger, connect through the lighter socket. works for my boat.
Post #458675 Thu Apr 09 2015 12:45pm
myfirstrrs
Does this need any change to wiring or can you charge through the lighter socket with ignition off?
Post #458692 Thu Apr 09 2015 3:12pm
jeffhunt
Not sure if the lighter socket is permanent live, which to charge through it should be. They do (on this site) a changing plug that fits into the trailer electric socket, you could use that then leave the panel in the rear window......
No doubt someone with all the relevant technical knowledge will come along soon and give us all the SP.
Post #458714 Thu Apr 09 2015 6:17pm
