Home > Technical > Few questions on my MY13 Black
Buster007
Can anybody help me out with how to use the heater using the remote control? I know I can set it to come on using the timer from the car but the instruction manual talks about using a remote control to turn it on with? Is there a separate remote to do this with (which I haven't got) or can it be operated by using the normal remote? My one has five buttons a padlock closed A padlock open Headlights button a Boot opening button and one with a red triangle So which one turns the heater on??
My other question is there is a ride setting (far left) with a wiggly road symbol 'Dynamic' what dose this do? When I use it there doesn't seem to be any noticeable change? Question Cheers Laurence.
Post #458154 Fri Apr 03 2015 10:55pm
PEACHY
Remote heating can be operated with a plipper it is a separate remote - google "Landrover FBH remote" if you have the hardware fitted Big Cry look on lrtopix if you cant see your full spec - pm me your VIN - I have full access & will look to see if its installed. Search using the function above it will show you how to check visually Thumbs Up
The setting with the wiggly road is Dynamoc control a much harder - solid ride is achieved once pressed less role more stability & it should be noticeably different Thumbs Up 16MY Estoril Blue SVR.............
Post #458164 Sat Apr 04 2015 8:20am
muddywheels
Milk Float Man
Remote heating is not included and will cost arm and leg at dealer. You can fit it yourself but needs activation by dealer - see here for more info http://www.rrsport.co.uk/forum/topic34755.html?highlight=remote Thumbs Up
Dynamic stiffens steering too and useful when you want to push things a bit more than normal Twisted Evil Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #458166 Sat Apr 04 2015 8:50am
Buster007
Thanks Peachy PM sent Thumbs Up Cheers Laurence.
Post #458187 Sat Apr 04 2015 1:13pm
Buster007
Thanks Muddy I didn't realise the remote was an extra! Big Cry I've properly been away from the brand too long - its all coming back to me now!! Rolling with laughter Cheers Laurence.
Post #458189 Sat Apr 04 2015 1:15pm
Paulcp
2013 Range Rover Sport SDV6 HSE Atacama Sand
Contact Bodsy on here if you want a cost effective route to getting the remote heat fitted & activated
Dynamic mode certainly helps the car's balance on the twisties here in Suffolk Thumbs Up
Post #458259 Sat Apr 04 2015 10:15pm
