![]() | Home > General (L494) > RR Sport builder changes |
Edd, IIRC the cars you configure now will not start rolling cown the production line until mid August, possibly later so you may find that if your build date is before mid-August you will not be able to add these items............. ie you will have one of the last 2015MY cars. The hands free tailgate appears also to have been rolled out for Evoque too which also gets the option of LED headlights on some models. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
eddkawasaki Member Since: 23 Feb 2015 Location: Lancashire Posts: 93 ![]() ![]() |
Hmmm mine is slated for a June build I wanted an ebony ebony interior but was told that ebony/lunar was as close as they got. Can't hurt to ask I guess. |
Good luck - might be worth going through Pete@land Rover rather than the dealer (wouldn't mind betting that 90% don't even know the configurator has changed so will be surprised when you ask!) 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Chrisr1806 Member Since: 23 Jun 2013 Location: Sussex Posts: 683 ![]() ![]() |
Am I the only one who doesn't unnderstand the need to LED headlights? I though the current Xenons were good enough.... Arrived: MY16 A/B SDV6 in Aruba, Ivory interior, piano black trim, black panoramic roof, spare wheel, blind spot monitoring, mudlaps and more... |
Chris have a look at the audi matrix led to see some advantage of LED http://www.audi.com/content/com/brand/en/v...light.html |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9152 ![]() ![]() ![]() |
One potential benefit of LEDs is the high lifetime compared to standard bulbs. Also they require less energy although once you have an array of them that's probably no longer true.
Don't forget to factor in the cost of the extra research they will have to do to make sure the condensation is present at all times |
Maidenmania Member Since: 13 Feb 2014 Location: Yorkshire Posts: 138 ![]() ![]() |
It would appear the new model will also have automatic access mode...... At long last! 2008 Factory HST- Sold
Solihull1 Member Since: 01 Mar 2015 Location: Solihull Posts: 87 ![]() ![]() |
Does that mean that it will automatically lower to access height when turning engine off rather than pushing the button, or is there something bigger that I am missing? Thanks |
philmw Member Since: 18 Aug 2006 Location: Nottingham Posts: 1690 ![]() ![]() ![]() |
Not the brightest idea if so as access mode is best enabled with the car moving (slowly). |
Fletcher Member Since: 28 Jan 2015 Location: Devon Posts: 481 ![]() ![]() |
Just come home from the dealer , my order is being put on hold so that I will get one of the first of the new ones , they were aware of the changes but not aware the configurator had changed so much .
HSE doesn't get Meridian now so 825w Meridan is £1000 and the Signature is £5000; AB still has 825 Meridan system so Signature system is £4k. ![]() |
What is your delivery date now? |
