![]() | Home > Technical > Slow to start.... |
tonytiger Member Since: 14 Sep 2013 Location: St.Neots. Cambs Posts: 308 ![]() ![]() ![]() |
Picked up my new tdv8 Sunday...... Been 6 months since last rrs but foot on brake and start button pressed seems to take a good few seconds before she fires up....
Thanks very much |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9087 ![]() ![]() ![]() |
Mine churns for a couple of seconds before starting. Did it that way before and after the starter was changed so I guess it's a "feature". 2012 SDV6 - it's missing a couple of cylinders
It's more of press the starter button and literally nothing for a couple of seconds then it'll turn the fire |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 954 ![]() ![]() ![]() |
as TT said, its not the fact the engine spins over for while it's a case of nothing happening for a while, all you get is lights on the dash and a "cold start in progress" message ,,,,, thats if you notice it inbetween the panic attacks and pressing every button you can find |
LandPhil Member Since: 10 Feb 2015 Location: Suffolk Posts: 227 ![]() ![]() ![]() |
The sensor that contiols the delay is the engine coolant sensor so the delay is not dependent on air temperature. I can't remember the exact figures but if you leave the car out on a very cold night, say -2deg and then a warm front moves through and the air temperatures warms up to say 4deg, when you press the button you will still get a long delay before cranking as the engine block is muich colder than the air termperature. It can be disconcerting and makes you prod the button, but actually it indicates that the system is working. |
harrygh60 Member Since: 16 Nov 2011 Location: London Posts: 395 ![]() ![]() ![]() |
Yes most certainly the glow plugs, warming up. Years ago you had to do this manualy,hold key in first position till glow plug light went out,then turn key to second position to activate starter itisme |
My mk4 Golf used to activate the glow plugs when you unlocked the door. When you got in you could just turn the key as if it were a petrol engine. Transparent in operation and worked very well.
Something more sinister is going on!!
myfirstrrs Member Since: 20 Jan 2014 Location: Lancashire Posts: 433 ![]() ![]() |
Just a thought but is your wife pressing the brake pedal hard enough? It needs a bit of welly and I know we had this issue in our house at the start. |
First time it happened 4am she got
Can't see any issues here!!
Agreed tony, that's pretty much what mine does. It does need some pressure on the brake. |
