Home > General > Camshaft sensors
james 201081
England 2010 Range Rover Sport TDV8 HSE Rimini Red
Camshaft sensors
Been having a intermittant sterting issue with my 2010 3.6 TDV8 RRS, Its been coming up with a camshaft speed sensor fault, Does anyone know how many cam sensors are on the vehicle? Or anyone have any simmilar issues
If anyone has a workshop manual that would be mutch appreciated
Thanks in advance
Post #457690 Mon Mar 30 2015 6:36pm
Paddi
There are two camshafts but only one sensor it seems.
Here you are:
http://www.rrsport.co.uk/gallery/albums/us...20TDV8.pdf
Or if you can't access that:
Many of us have CD versions of the workshop manual from the usual source (bay of e) for between £2 and £20 but they all seem to be the same. It is a big file (198Mb) so too big to post on the forum.
Edited (sorry - c Censored ed it up the first time. Rolling with laughter 2008 MY Java Black TDV8 HSE
Post #457790 Tue Mar 31 2015 4:50pm
james 201081
Paddi, thanks for that, clears things up a little unfortunately replaced the one cam sensor and still having starting issues. Landrover are now going to replace the crankshaft sensor which they tell me involves removing the transmission to change. Not good news Sad will have a look on ebay for a disc will be useful in the future.
Post #457793 Tue Mar 31 2015 5:03pm
Paddi
Hi no problem,
Well I hope it is being done under warranty. Interestingly the manual lists the CKP as a possible cause for NON starting but not as a possible reason for DIFFICULT starting. This is what the manual suggests:
Difficult to
start:
Possible Causes:
Glow plug system fault
(very cold conditions)
Low/Contaminated fuel
Air leakage
Fuel pump module (lift
pump) fault
Low-pressure fuel
system fault
Blocked fuel filter
Fuel volume control
valve
blocked/contaminated
Fuel pressure control
valve
Exhaust gas recirculation
(EGR) valve(s) fault
We hear many stories on the forum about LR dealerships woeful approach to diagnosis which usually seems to involve mucho changing of very expensive parts more or less at random until they get lucky. To add insult to injury they then don't put the car back together properly setting off a chain of further faults. Just ask RRSTDV8! 2008 MY Java Black TDV8 HSE
Post #457802 Tue Mar 31 2015 5:39pm
james 201081
Fortunately or unfortunately I only bought the car last week from an independent garage so they are picking up the cost.
The starting issue is intermittent so when it does decide it wants to start it fires straight away, otherwise just cranks over, so sounds like the crank sensor could be a good call. Hopefully it's not the start of things to come as this is my first Range Rover. Just ordered a manual and put on a comprehensive warranty for when my other runs out just for peace of mind.
Post #457810 Tue Mar 31 2015 6:38pm
