Home > In Car Electronics > Bluetooth not seen on 2006 tdv6 hse....
fretlessfender
Hi folks,
RRS owner for all of two weeks and puzzling over how to get the bluetooth to work. Head unit and satnav work as they should, has the buttons on the right of the steering wheel and has the Nokia module hidden behind the panel on the drivers side in the boot + plus the antique connections in the central storage compartment.
So, I turn on the bluetooth on my HTC and it doesn't see anything. Am I missing something simple such as the head unit needing to be turned on (tried with it on)? Or....
Any suggestions?
Mike
Post #457517 Sun Mar 29 2015 1:08pm
Maxarn58
Sweden 2006 Range Rover Sport TDV6 HST Java Black
Hello fretlessfender.
You must "activate" the bluetooth-unit first..
If You toggle the green button on Your steeringwheel,
in the radiodisplay it should say "no phone attached".
After doing that, you can search for the bluetooth in your car.
Hopefully, this will be of some help.
Uffe As a rule, I always resist temptations,
unless they are irresistible.
My Ride: 2006 RRS HSE TVD6 Java Black/Cherry Woods with HST factoryfitted pack.
Post #457518 Sun Mar 29 2015 1:27pm
fretlessfender
Thanks, Uffe,
Tried this and the bluetooth on my HTC still doesn't 'see' the RRS. Could this be a duff module?
Post #457519 Sun Mar 29 2015 1:41pm
Paddi
Have you tried pairing another 'phone?
You could also try a hard re-set. Fixes a lot of these little glitches. 2008 MY Java Black TDV8 HSE
Post #457537 Sun Mar 29 2015 6:58pm
jimbg
Are you sure you have blue tooth?
Maybe you have the remains of a hard wired Nokia phone install? 2026 P460e Autobiography on order
2022 HSE Dynamic P400e
2006 HSE
Post #457538 Sun Mar 29 2015 7:03pm
Bodsy
Site Sponsor
In the boot, rh side, with MoST connector is definitely factory BT.
You should find LandRover when you have BT on. I assume your volume on the stereo works ok? Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #457559 Sun Mar 29 2015 9:26pm
fretlessfender
Thanks, Bodsy
Next trick will be to try another phone. My HTC Works with every other BT going, but not the RRS. Crying or Very sad
Volume is fine on the radiogram........
Post #457577 Mon Mar 30 2015 6:59am
fretlessfender
Lolol. Works perfectly with my wife's phone. Confused
Post #457585 Mon Mar 30 2015 9:23am
Bodsy
Site Sponsor
you've tried completely powering down and removing the battery on the phone? Is there a newer firmware/software update for the phone? Bodsys Brake Bible
See it HERE
Post #457595 Mon Mar 30 2015 10:17am
fretlessfender
Thanks, Bodsy,
Both phones are identical - if anything, mine will have the most recent update installed. It's a phone issue, so I'll clear out all the old BT stuff and try from scratch.
Have pm'd you about some updates when convenient.
Thanks for everyone's input and help!
Mike
Post #457597 Mon Mar 30 2015 10:25am
Bodsy
Site Sponsor
Have replied Thumbs Up Bodsys Brake Bible
See it HERE
Post #457598 Mon Mar 30 2015 10:28am
