![]() | Home > Maintenance & Modifications > winter is here, drl's to be installed |
| Gaz Member Since: 19 Oct 2013 Location: Bristol Posts: 246
How long did it take you with the heat gun to remove a lens? |
| tanloverluke Member Since: 19 Mar 2013 Location: Honiton Posts: 917
soz late reply! it took me about 10 minutes in all. I just went around with the gun for most of the time, slowly softening the glue until I could pull apart the lens. Once you lift one end up then the rest is simple. Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
.....wow....loosens that quickly! |
| Jemmountford Member Since: 04 Oct 2014 Location: Warwickshire Posts: 20
Looks good, please keep the pictures coming as I fancy having a go at this myself. How did you attach the rings to the headlight surrounds? Where are you going to route the wires ? Sorry, questions questions...... |
i glued the rings down with a glue gun. drilled a hole through each rim for the wires.
I think most people have drilled the back and sealed. |
Launch this week. Work busy right now. All that is left is the lense and final polish
| sparky8181 Member Since: 02 Nov 2012 Location: West Midlands Posts: 588
WOW, looks amazing Luke, done a top job of that |
Thanks sir, and apologies for not buying those rings from you. The dabhees after sales service was poor, esp. with a premium number and no one ever answering., despite me being connected and put on hold. I couldn't even get through. Better to buy from a reputable forum member who is on tap |
.....they look absolutely superb! |
| martin.b Member Since: 24 Mar 2015 Location: West Yorkshire Posts: 12 |
Hi, I'm new to this forum, I joined to gather some information about doing the headlight conversion my self, its a pity they cost too much to have them installed from eBay. just a few questions:
Hi Martin.
Oh yes.....when putting the lenses back on, apply more heat and they should re seal.
