| RRSPORT.CO.UK | ||
|  | Home > Maintenance & Modifications > Brake disc removal |
| tonytiger Member Since: 14 Sep 2013 Location: St.Neots. Cambs Posts: 308      |
 Hi all..... On my MINI (sorry mods if you want to move to off topic) I've just changed my front discs (one side grrrr) but the retaining screw is fubar on the otherside.... Someone's tried to remove using wrong size torx bit and is now useless....
|  Wed Mar 25 2015 5:18pm |
| Russben Member Since: 27 Mar 2013 Location: Lancashire Posts: 278    | Use a reasonably big drill bit & drill the head off. If you're lucky the heat from drilling may well loosen the screw anyway & you can then undo it. Alternatively, try using a centre punch to 'drift' it around to undo it first. The screw isn't that important as the wheel holds the disc on anyway. I'm in the shed, I'll be back in the real world in a minute.
|  Wed Mar 25 2015 5:35pm |
| Paddi Member Since: 06 Jul 2012 Location: Hertfordshire Posts: 1563      | ^^ Good advice.
|  Wed Mar 25 2015 5:45pm |
| tonytiger Member Since: 14 Sep 2013 Location: St.Neots. Cambs Posts: 308      | The other side as soon as the torx screw was off the disc fell off so can see it being corroded on... But great advice thx guys, I'll try with a centre punch first then if not out with the drill   | ||
|  Wed Mar 25 2015 5:50pm |
| Bodsy Site Sponsor Member Since: 03 Feb 2007 Location: Shropshire Posts: 2162    | id try the punch first, on the outside of the head to try to shock/leverage it round. Usually once it starts, it carries on no problem. Bodsys Brake Bible
|  Wed Mar 25 2015 6:32pm |
| Posting Rules
 [/URL]
[/URL]
