Home > Technical > Juddering at 70mph
Chado
United Kingdom 2008 Range Rover Sport TDV6 HSE Alaska White
Juddering at 70mph
I've noticed my RRS starts juddering when it reaches 70mph. I have no others problems when driving below this speed. I've had the wheels re-balanced and that's not solved it.
Any ideas?
Post #446483 Sat Dec 27 2014 5:59pm
BKHK
Just the front wheels or the whole car? Gone - 2008 Stornoway Grey RRS 2.7 TDV6
Post #446524 Sun Dec 28 2014 12:51am
Chado
The whole car judders, it was the front wheels I've had balanced.
Post #446525 Sun Dec 28 2014 12:55am
BKHK
Try having all the wheels balanced. This can be very tricky to solve. My 2008 had:
Wheels balanced, tyres changed, wheels changed, disc rotors changed, steering rack changed, prop shaft changed....at that point I refused to accost it back with <6000 miles from new. Next change was the rear differential but I never found out the result. Technicians from the UK visited Oz to try to fix it.
I hope yours is simple. Gone - 2008 Stornoway Grey RRS 2.7 TDV6
Post #446563 Sun Dec 28 2014 3:21pm
gogsy1956
You don't,say what mileage is on your sport, but as you have already tried, wheel balance or even 4 wheel alignment is the first route to go down. After that, if you have a higher mileage car the torque converter could be the problem. I believe it,s referred to as the cattle grid effect, because it's just like driving across one.
Do a search on here for that subject, or vibration......... Megaflush is another subject that mentions this problem 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #446721 Tue Dec 30 2014 6:50am
Jay2012
2012 Range Rover Sport SDV6 HSE Santorini Black
Do look at the vibration posts, but.. Sometimes the simplest things work.. I had same issues, LR replaced half shafts; and considered propshaft.. However, it turned out to be wheel balance! They were balanced by a specialist and the vibration went. The dealer found this by trying a different set of wheels before ordering all the prop parts suggested by LR.. Good on them. So, if possible try that too
Post #447502 Mon Jan 05 2015 9:36pm
Minshy
I had same issue. It turned out to be water in one of the back wheels. Tyre guy said never ever seen that before.
This has now happened twice,
Will upload pic when phone is charged up
Doh
Steve
Post #447505 Mon Jan 05 2015 10:02pm
Chado
It was water in both back tyres! Not sure how it got in there - anyone know? Embarassed
Post #456596 Fri Mar 20 2015 11:21pm
Camelrock
Water could get into your wheels from the airline if the garage you use hasn't drained there compressor and don't have a water trap. 2008 G4 RRSport TDV8 current
2009 TDCi 90 current
1994 Dakar current
Post #456620 Sat Mar 21 2015 7:40am
Gaz
England 2007 Range Rover Sport TDV6 HSE Stornoway Grey
.....warped brake discs maybe? I was born with a photographic memory. Shame it didn't develop!
".....do you boys know what the word Nemesis means?...."
2007 2.7 TDV6 in Stornaway Grey.
EGR Blanked.
Re-mapped by Alive Tuning.
Post #456632 Sat Mar 21 2015 9:35am
Minshy
Camelrock
That was my first thought.
The first time it happened to me, I hadn't put any air in my tyres since having it and it was a gradual increase in vibration.
When I took it to the tyre place and found the water he checked his airline which had water filtration on and it was clear of water.
When the tyre was balanced again ,it was fine for a good 4months but I noticed it again and took it back, same problem.
So far it has been fine.
My car does stand during the week as I use a van for work, I was thinking it could possibly be condensation build up
I have the original tyres on and they are Pirelli scorpion
Car is in for second service and will speak to service manager about this,
A real head scratcher
Steve
Post #456786 Sun Mar 22 2015 5:12pm
Russben
Could the water be from a pressure washer? You'd have to hold it close to the tyre bead for a while, admittedly. I'm in the shed, I'll be back in the real world in a minute.
Gone- 2010 TDV6; Hello 2017 SDV6.
Post #456788 Sun Mar 22 2015 5:28pm
Minshy
Hi chaps,
Had my car in for service and the manager was aware of water ingress in the tyres.
They have resealed the tyres and re balanced them up FOC, it might be worth anyone else havin this issue giving the dealer a call
Steve
Post #457174 Wed Mar 25 2015 7:44pm
Htailor23
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Santorini Black
I have had the same problem Perelli tyres, water in 3 tyres. I'm told by my Land Rover garage it's a known problem with these type of tyres, go for different ones next time.
Post #461924 Thu May 14 2015 2:39pm
Papa kilo
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Baltic Blue
And another
Hi guys, just had the same issue on my 2013 Autobiography, nearly 1 litre of water in one rear tyre only the other three were bone dry, I've never used an airline. The dealer won't commit just said they are aware of the issue?
Post #462141 Sun May 17 2015 10:30pm
