Home > Technical > question has anyone got an answer
madmackie
United Kingdom 2005 Range Rover Sport TDV6 HSE Bonatti Grey
My fbh keeps locking out none start I have forced it to start with the webasto software do the fbh have a glow plug ( daft question ) are they easy to replace or is there another issue causing it to lock out pump works fine reads full etc thx pete "Remember its easier to say sorry than it is to get permission " especially off the Mrs !!
Post #455666 Thu Mar 12 2015 7:12pm
http://www.rrsport.co.uk/gallery/albums/us...en-WEB.pdf
Is this any help? 2012 SDV6 - it's missing a couple of cylinders
Post #455683 Thu Mar 12 2015 9:20pm
riverblanche
there are loads of threads on the D3 side, but if you can fire it from the WTT I would let it have a few 1/2 hour burns and see if that clears it out enough Question
there is always the option of brake cleaner Shocked but have a read first.
it does have a glow plug which has a test function in the WTT try 30sec at 100% you may well get a bit of smoke from the intake
But if you are thinking about replacing the glow plug you may as well give it a strip down and decoke.
happy reading Thumbs Up
Post #456135 Mon Mar 16 2015 11:22pm
