Home > Technical > Alternator Failed.
LandPhil
United Kingdom 2013 Range Rover Sport SDV6 HSE Ipanema Sand
Alternator Failed.
Shortly after starting this morning got a warning CHARGING FAULT. Called LR Assist and the guy said it won't be the alternator they rarely fail on the 3.0 TDV6, probably a loose conection at the negative terminal. Wrong! the alternator has gone tits up or it is not "talking" to the electrical system.
Car with dealer and LR Approved are dusting off the warranty. Apparently the cost will affect the national GDP figures. Big Cry
One month's ownership - 2 major faults!!!!
LR Assist said most unusual the Sport is generally most reliable!
Post #454886 Fri Mar 06 2015 2:52pm
drdelrrs
^^^ "LR Assist said most unusual the Sport is generally most reliable!"
There's one or two around on this site might want to take issue with LR on that statement.
Post #454907 Fri Mar 06 2015 7:34pm
LandPhil
I'm one of them!
Dealer has found a TSB covering my fault and it requires the wiring loom from the alternator to be replaced, so they are starting there. Will know more on Monday
Post #454910 Fri Mar 06 2015 7:44pm
LandPhil
RIGHT HAND? LEFT HAND?
Told this morning by LR that the part is not available until 20th March at the earliest.
Call form dealer this PM, LR have dispatched the part so hope for the car back tomorrow.
Post #455432 Tue Mar 10 2015 6:05pm
LandPhil
Car home and working - fingers crossed.
Post #455664 Thu Mar 12 2015 7:04pm
LandPhil
Same fault back again Censored
LRA coming in the morning - one sided conversation with supplying dealer will follow.
Post #457055 Tue Mar 24 2015 7:59pm
LandPhil
Fixed! New alternator and wiring. The fault was a long standing loose connection at the positive post on the alternator. This caused intermittent warnings and failure to charge. Also it arced and burnt away the post, hence the new alternator. Fingers crossed that this is end of the saga.
Post #457910 Wed Apr 01 2015 5:46pm
Loose connections (and loose pipes) seem to be stock-in-trade for LR products, especially if they're worked on by LR dealer technicians... Censored
Hopefully this will be your last issue Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #457911 Wed Apr 01 2015 5:58pm
LandPhil
Thanks and I hope so. Over the last few weeks I have had an Evoque, Kia Sorento and a Nissan X Trail while mine was in dock. All of them were high spec, but when I drove the RRS home yesterday I realised that once you have driven a RRS nothing else compares. I'm hooked so I had better just put it all down to experience.
Post #457983 Thu Apr 02 2015 8:59am
